Will Electronic Ignition Help Solve My Problem?
  • TLH101
  • TLH101's Avatar Topic Author
14 Dec 2006 16:57
#99639
My bike is getting hard to start. Sometimes it just cranks, but wont start. As soon as I release the button, it will fire, and maybe start. Other times it kicks right off as soon as I touch the button. Warm or cold, does not seem to have a pattern. The points are nearly new, and the gaps are right.
One other thing I noticed, I have a ticking noise that sounds more like a spark leak than valve train. I put bike in the shed and turned out the light to look for a spark, and saw none. I removed the point cover and even saw no spark at the points when running. I assume that is good?
Thinking of installing a Dyna S electronic ignition. Any thoughts?
  • steell
  • steell's Avatar
Re: Will Electronic Ignition Help Solve My Problem?
14 Dec 2006 18:14
#99656
I'd almost bet that the WG relay mod would solve your starting problem.
  • TLH101
14 Dec 2006 18:19
#99658
OK, so what's that?:dry:
  • steell
  • steell's Avatar
14 Dec 2006 19:47
#99681
Have you checked out the "Filebase" link under the "KZ Information" tab at the top of the page? Tons of useful info there.
Coil Mod in Filebase
  • kawsakiman
  • kawsakiman's Avatar
14 Dec 2006 20:14
#99689
www.wgcarbs.com scrool to the bottom. follow his advice to the tee.i did it and there was a night and day difference.
  • TLH101
15 Dec 2006 18:47
#99892
Thanks a lot guys, I'll give it a try. Looks like it should work pretty good.:)
  • outatimeoutlaw
  • outatimeoutlaw's Avatar
18 Dec 2006 16:11
#100340
I have the same problem with my SPECTRE & was considering the coil repower mod on wire georges site is that what you are refering to?
Pay attetion to what the asshole said as they allways speak the truth
  • TLH101
18 Dec 2006 16:36
#100346
Pretty sure that's what they are reffering to. Thats what I am planning to do. Make good sense to me. Mine really acts like a voltage loss during cranking and I can see how this mod would solve that problem.
BTW, I just bought a '83 Spectre 1100. Waiting for the seller to come up with the title before I pick it up. Looks like I'm going to part it out though. i just don't need another project.:P
Post edited by: TLH101, at: 2006/12/18 19:37
  • tnutz
  • tnutz's Avatar
18 Dec 2006 17:01
#100350
had the same prob with my GPZ, would crank and crank, and would finally start, cleaned up my battery connections and coil connections and it starts first try.
  • Bluemeanie
  • Bluemeanie's Avatar
27 Dec 2006 19:16
#102116
Does sound like a weak spark, had same basic problem as you. Won a set of Andrews coils with Accel wires on ebay and now it lights off so easy even on the coldest morning. When warm it starts within 1 revolution of motor, and I'm still going to do the coil mod.
Post edited by: Bluemeanie, at: 2006/12/27 22:17
  • arobsum
  • arobsum's Avatar
28 Dec 2006 15:50
#102244
i have got the same problem..going to buy an elec. ignition and see if it helps.
  • JR
  • JR's Avatar
28 Dec 2006 17:48
#102261
I dont thnk I'd spend money on an electronic ignition until I had gotten a little digital multimeter and a manual and checked out all the electrical pathways from points to plugs. I once traced a weak spark to a corroded connection underneath the battery. The battery breather had come off and acid had dripped down on a connection. Once it was fixed up the bike ran fine.
With a meter you can also check the voltage at the coils. The WG coil mod is worth doing even if you only gain a half a volt.
Good luck.
