78 KZ650 Wiring diagram
  • auburn1956
  • auburn1956's Avatar Topic Author
23 Nov 2005 21:23
#9945
I just picked up a 78 KZ650 and none of the lights work except for the oil light on the dashboard. It must be a single point failure for nothing to work, probley just a loose connection someplace. Anyone have a wiring diagram for this bike that could be email'ed or any suggestions would be appreciated. By the way, the ignition system works fine and the engine runs good once i cleaned the carbs. Thanks, Dan
  • 1hotz
  • 1hotz's Avatar
Re: 78 KZ650 Wiring diagram
23 Nov 2005 23:39
#9952
The first thing is the same suggestion we give everyone, get a clymer manual for your bike. Ebay usually has them.
beyond that you could just check connections behind tthe headlight, and taillight. If you have a test light, or multimeter it will atleast give you a place to start.
  • OnkelB
  • OnkelB's Avatar
24 Nov 2005 11:22
#10026
Try this link:
www.kt.rim.or.jp/~michiaki/z650/maintenance.html
Scroll down to the bottom of the page and find your model - click on the diagrams to enlarge.
Post edited by: onkelb, at: 2005/11/24 14:23
77 KZ 650 B1, 82 GPz 1100 B2.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
24 Nov 2005 16:12
#10065
Welcome to KZR auburn1956. Check your fuses while your at it too. Try spares, as sometimes they will look good, but are shot.
Post some pictures of your 650 when you can.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • auburn1956
25 Nov 2005 09:11
#10157
Thanks for all the responses. Once i get the roadmap(Schematic)it is usally pretty easy to find the problem. I will post pictures as soon as i get a sunny day, It has a tendency to rain a little in Washington this time of year, but also allows me to work on the bike. Thanks for the help. Dan
  • 1hotz
  • 1hotz's Avatar
25 Nov 2005 09:38
#10162
I hope you get it fixed easily. most of the time it is something pretty simple to fix, it's just finding it.
Good luck.
Dan.
  • loudhvx
  • loudhvx's Avatar
25 Nov 2005 10:29
#10164
78 650 D1
I tried to post the diagram here, but the website won't let me. If I make it smaller, it would be useless.
These limits are getting to be a nuisance.
Post edited by: loudhvx, at: 2005/11/25 13:31
  • loudhvx
  • loudhvx's Avatar
25 Nov 2005 11:43
#10172
I put it in the filebase for 78 650 D1.
