stator. is there anybody out there?
- pato
12 Dec 2006 20:39
a stator for a kz 650 1980 can replace a stator for a kz 650 B 1978?
what's the result of putting a stator with newer magnets?
is it easy to install?
thank you
thank you
- donthekawguy
Re: stator. is there anybody out there?
12 Dec 2006 21:02
If it aint broke don't fix it. the stators hardley ever go bad and they all put out the same amount of juice. If your having charging problems try checking your regulator.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- JMKZHI
Last edit: 03 Dec 2008 13:47 by JMKZHI.
- SpokeWheel650B
13 Dec 2006 20:21
Pato...I am guessing your 650 is the B2-later permanent magnet type alternator, right? The 1980 stator windings will bolt onto your '78 no prob, not sure reagarding the wiring colors but they are compatible in operation (may just be a matter of switching plugs ends to match your bike's harness). Don is right, though...they are very rugged and last a long time.
good luck!
good luck!
- SpokeWheel650B
13 Dec 2006 20:25
good luck!
good luck!
