KZ650 blade fusebox conversion
- inline79
10 Dec 2006 21:45
There was a document discussing fusebox conversion on a KZ1000 and I thought I'd submit a photo of the same conversion (with the same parts) on a KZ650.
The automotive fuses are so much easier to find and I think the contacts on these fuses are far more reliable.
I think problems can arise with the old style fuses if you subsititue the wrong length fuse and you get some bad contacts in the box. The arcing from the bad contacts can create electrical gremlins that you may not immediately trace back to your fusebox. This is a quick and reliable upgrade for all our old KZ's.
Remove old fusebox:
- photograph or write down the wiring in the fusebox for reference later.
- Remove the old box from the bike by pulling the fuses, wires and the rubber holder.
- cut off or remove the old fuse holder connectors, leaving pigtails.
Install new fusebox:
- $4.99US 4-position fuse holder from Advance Auto Parts
- crimp on new connectors (or just use pliers carefully). Soldering is optional. You may have to separate the 4 pins that come on one rail - our bikes don't have the fusebox common ground that many cars have.
- modify one of the mounting holes to take the old rubber holder and hook the box where the old one use to be - there is just enough clearance to the side cover.
- Test all circuits
Time: < 1 h
Cost: $5US (scavenge the fuses)
Additional "Fast-ness" of bike: ZERO
Other tips:
- these are self-cleaning contacts but still a good idea to seal the box somehow.
- Don't use a 30Amp fuse on the 20A circuit like I have, I have to "borrow" a 20A from work tomorrow.
Remove old fusebox:
- Test all circuits
Time: < 1 h
Other tips:
- 77KZ650
Re: KZ650 blade fusebox conversion
10 Dec 2006 21:59
looks good! I think Ill probably do the same to mine
Scott
Scott
07 MDP Rookie of the Year
- reborn650
10 Dec 2006 22:14
Thanks Inline - Thanks for the info. I like the swap. Gonna put it on my 2do list for the hibernation months.
Cheers-COlin Firth-Ontario Canada
1977Kz650Custom -Miss January 2007 Kzr Calendar. 810 big-bore with lottsa go-fast goodies tucked away inside. A silver sleeper:)
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
- rstnick
11 Dec 2006 06:40
Yes, this is something I should do as well. Thanks for the write up.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- bill_wilcox100
11 Dec 2006 08:29
Looks good. I did something similar plus I put a combination of red LED in series with a resistor across each fuse. Now, if a fuse blows (open-circuit), the LED turns on.
The resistor value is chosen based on the maximum current capacity of the LED you use.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- inline79
11 Dec 2006 09:46
Looking quickly at who has replied this morning, I want to remind our friends down south that contrary to popular belief, the Laws of Electricity do NOT change when you cross the border. I did in fact buy the parts in YOUR nation's Capitol of all places.
:laugh:
- wireman
11 Dec 2006 13:06
inline79 wrote:
once i get that far i will try something similarB)
thank god!the whole north/south pole thing had me concerned!:SLooking quickly at who has replied this morning, I want to remind our friends down south that contrary to popular belief, the Laws of Electricity do NOT change when you cross the border. I did in fact buy the parts in YOUR nation's Capitol of all places.
:laugh:
