Wiring Harness Question
- Nevco48
28 Nov 2006 14:19
I'm rebuilding a 1978 KZ 750. The PO messed up the wiring harness to the point that it was easier to shell out $25 for a replacement on eBay. I carefully used my tags from the old one to get everything hooked up again and it seems like everything works right. However, the new harness has three wires that dead-end in the headlight bucket with no where to go. With my tester, I determined that one is always charged, and the other two are wired with the L & R turn signals. Each of the three wires ends in a medium sized female connector. I can't find anything on the wiring diagram to hint what these might be for- anyone got any ideas?
- wireman
Re: Wiring Harness Question
28 Nov 2006 16:16
a lot of wiring harnesses have extra wires.sometimes its just for a differat model,sometimes its for use in differant area or country;)
- Shoe48
- Live each day as it is your last
28 Nov 2006 16:40
What color are they As I have a 79 kz750 sitting right behind me I will look for ya ..
Post edited by: Shoe48, at: 2006/11/28 19:42
- arobsum
- rstnick
30 Nov 2006 06:55
Signal beepers? To remind you you've left your signals on.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- arobsum
30 Nov 2006 15:16
rstnick wrote:
i still have the original beeper on my kz900..i believe it only uses two wires....(i think!)Signal beepers? To remind you you've left your signals on.
