ARGGGGH
  • tnutz
  • tnutz's Avatar Topic Author
ARGGGGH
18 Nov 2006 15:40
#92991
decently nice weekend to putz around the city on the GPZ....had the battery out of the bike for 2 months charged it once about 3 weeks ago...thought it would be okay, put it in the bike.......NOTHING, no lights even. Now i can barely get enough charge in it off of the charger. it seems to hold enough to run things, but no cranking power. As soon as i put the charger on it in the bike and hit the start button, she fires right up. I was told this was a new battery. Do they go bad often???? or did i just get a lemon.:angry:
  • The Milkman
  • The Milkman's Avatar
Re: ARGGGGH
18 Nov 2006 15:59
#92992
I never believed it until it actually happened to me, by any chance did you have it sitting on a cement floor? That actually does kill a battery.
If not is it full of water? Distilled of course. Also, if the top of the battery is damp, this will cause it to go dead also, the current will gradually short across the battery. A slow trickle charge should bring it back to life.
I have even seen cases where if you hook a 12 volt bulb inline between the post and one of the charging cables so the power has to go through the battery to light the bulb it will help revive it.
Good luck,
Les
  • tnutz
Re: ARGGGGH
18 Nov 2006 16:23
#92998
wasn't on cement, topped the water off with distilled right after i took it out. maybe i will try to charge it again tomorrow. if not i guess i buy a new one.
  • tnutz
Re: ARGGGGH
19 Nov 2006 19:03
#93305
well, put in the battery out of the ole ladys gs 550..waay smaller battery too, and it fired first time easily. SO obviously this battery is pooched. I charged it for half an hour and it hardly light up a 12 volt bulb. supposed to be a new battery too. Water level is good..so hopfully warranty will replace it.
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
Re: ARGGGGH
19 Nov 2006 19:06
#93308
These small MC batteries are pretty cheap and don't go for more than two seasons usually without some if not all of the performance gone out of them. One dying is a season is no big surprise to me either.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: ARGGGGH
19 Nov 2006 19:08
#93311
F.Y.I...most battery warranties are usually about a year from purchase date.Some are only 9 months.
I'd get it replaced as soon as You can.B)
1977 KZ1000 A-1
  • inline79
  • inline79's Avatar
Re: ARGGGGH
20 Nov 2006 23:38
#93665
Did you check your charging system? Could be it doesn't charge the battery well and the battery was already partially discharged when you took it off the bike.
A month partially discharged will wreck a battery. This one's already hooped. Check that charging system!
  • grace1
  • grace1's Avatar
Re: ARGGGGH
21 Nov 2006 00:17
#93667
g,day
just a thought mate ,depends on your charger output you may have to leave it on charger a lot longer than you think
i know when my deep cycle boat batt goes low it takes a long time to top it up again
chk your charger out put in amps
good luck
graemeB)
bendigo australia, gold mine country
MY COLLECTION 1978 B3 KZ750 AND 1980 GS1000G
  • JMKZHI
  • JMKZHI's Avatar
Re: .
21 Nov 2006 06:02 - 03 Dec 2008 11:26
#93691
del
Last edit: 03 Dec 2008 11:26 by JMKZHI.
  • tnutz
Re: ARGGGGH
21 Nov 2006 17:47
#93881
charging system on my bike is fine. i had the dealer check it when i bought it. i had the battery load tested today...it's gone. So warranty got me a new one.
  • tnutz
Re: ARGGGGH
21 Nov 2006 17:49
#93884
