- JMKZHI
Last edit: 22 Feb 2013 11:39 by JMKZHI.
- JMKZHI
- Nevco48
Re: Stator removal?
13 Nov 2006 20:33
Well, there you go. Answered your own question. I was interested to see if anyone had a slick solution- just this weekend I practically tore my fingers off with the same issue. Kept telling myself "don't pry with tools, don't pry" finally the stator popped out. Tight fit on those little buggers!
- wiredgeorge
Re: Stator removal?
14 Nov 2006 05:49
They are generally in there pretty tight. The best way to remove a sticky one is to turn it over and find a wooden work bench surface. Grasp the stator cover in your hand and bang it on the work bench. That will pop the stator out after the bolts have been removed.
- JMKZHI
