1982 KZ250 CSR compatible starter motor?
- crd
11 Nov 2006 13:50
Working on getting the 1982 running. Starter motor's completely shot. I have a 1980 KZ250 that I'm using as a donor bike, but the starter's just a tad different, and it won't fit on the 1982.
Scrolling through ebay, I see a number of used starters for sale. It seems that the 1982 KZ250 CSR is not very common. Do any of you know whether other models have a compatible starter motor? I need to find something cheap -- which precludes me from buying a new/rebuilt one.
Appreciate any suggestions you might have.
Thanks,
Chris
Thanks,
Chris
- crd
- Shoe48
- Live each day as it is your last
Re: 1982 KZ250 CSR compatible starter motor?
14 Nov 2006 07:43
I had an 83 KZ 250 with a bad starter ,, I used one from a KZ 200 But dont realy remember there being any real differance .. ? I might have changed end caps ??
- flht1997
14 Nov 2006 07:54
is it just the housing that is different. maybe take the guts out of the good one and put it in the bad one
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- crd
15 Nov 2006 07:34
You know, I'm going to go out there this weekend and pick up the project again, and see what I can do between the burnt out 1982 starter and the apparently okay 1980 starter. I put this thing down several months ago.
Problem with the current setup is that the electrical connection/knob/thingy on the two starters is in a different place, and the 1980 one won't fit right on the 1982. Perhaps if I disassemble them and do some switching around of parts, it'll work.
- wiredgeorge
15 Nov 2006 07:42
Go to Kawasaki.com and user info and then parts diagrams for your bike and find the starter. Once you click on the starter part number it will tell you what other bikes the part number is valid for.
- wireman
15 Nov 2006 09:22
how about just rebuilding your starter that way you arent gambling on a used starter;)
- loudhvx
15 Nov 2006 09:27
Last time I tried to buy brushes for a Kaw starter, they were over $100, so I bailed. Maybe you can get them cheaper somewhere. If someone knows of a source please post it.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- flht1997
15 Nov 2006 10:00
if the terminal is clocked in a different position, is it possible to remove the through bolts and rotate the housing 180 degrees?
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
89' BMW R100RT
06' KLR650
- pumps
18 Nov 2006 21:46
crd: I am local if you need any help...I DID know where there were a couple of 81? csr 650s...Don't know if they are still there.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
