Dyna 2000
  • kz-mtd
  • kz-mtd's Avatar Topic Author
Dyna 2000
10 Nov 2006 16:46
#91103
Would the Dyna 2000 help with heating issues when using a big block :blush: :huh: :whistle:
  • loudhvx
  • loudhvx's Avatar
Re: Dyna 2000
10 Nov 2006 16:51
#91105
Not sure what you're asking. The Dyna won't make the engine run much cooler, if that's what you're asking. It will allow you to alter the timing, which may reduce the heat a little, but as long as your bike is setup correctly now, it won't make a huge difference, at least, not that I can think of. If the timing is off, can't you can alter the existing timing?
Post edited by: loudhvx, at: 2006/11/10 19:52
  • kz-mtd
Re: Dyna 2000
11 Nov 2006 10:44
#91231
loudhvx wrote:
Not sure what you're asking. The Dyna won't make the engine run much cooler, if that's what you're asking. It will allow you to alter the timing, which may reduce the heat a little, but as long as your bike is setup correctly now, it won't make a huge difference, at least, not that I can think of. If the timing is off, can't you can alter the existing timing?<br><br>Post edited by: loudhvx, at: 2006/11/10 19:52
Thanx
