ignition pickups for 1981 KZ650 - will they work on '80 KZ1000 ST?
  • wickedquick
  • wickedquick's Avatar Topic Author
04 Nov 2006 21:13
#89743
Anyone know if a set of ignition pickups for an '82 KZ 650 CSR will bolt up to my '80 KZ1000 ST? Look about the same to me.
  • bob_z1
  • bob_z1's Avatar
Re: ignition pickups for 1981 KZ650 - will they work on '80 KZ1000 ST?
04 Nov 2006 22:30
#89749
don't think they will........
need one for an ST? I might have one
  • wickedquick
05 Nov 2006 04:32
#89759
Yes, I really could use a good one. How much do you want for it?
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
05 Nov 2006 05:03
#89760
I have used the 650 parts on my big bikes. The green ground wire doesn't need to be used.
I can't remember if i used a 1000cc backing plate or not. If the mounting holes line up you are good to go.
  • wickedquick
05 Nov 2006 10:48
#89815
Thanks Roy, will give em a try.
  • loudhvx
  • loudhvx's Avatar
05 Nov 2006 19:51
#89896
Rstnick put a 1000 timing plate onto a 650, but he had to cut it down because it was too big for the 650.
Rob, you out there?
