battery chargers
- phil
battery chargers
03 Nov 2006 08:34
sadly i just winterized my baby for the winter. i brought the battery inside. here's my question. i bought a battery tender which apparenty has a trickle charge and shuts off when battery is fully charged. i was wondering if i it's ok to leave the yellow plastic filler plugs in place for the winter with the charger turning on and off when needed .if not , what's the point of the battery tender if you have to keep on removing and replacing the plugs ?
- loudhvx
Re: battery chargers
03 Nov 2006 08:46
phil wrote:
The battery has a seperate vent for releasing gases, if that's what you're worried about. I see no reason to remove the plugs except to add water when it's low.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- phil
03 Nov 2006 14:22
thanks. that's what i thought the overflow tube was for.
