bypassing the cutout diode pack on a KZ550
- woodz
18 Nov 2005 13:36
a friend of mine is building a KZ550 chop, the ignition unit has a brown/white wire which goes to the diode, sidestand switch etc, how do we do away with this circuit?
thx in advance
cool site BTW
Post edited by: woodz, at: 2005/11/18 16:49
thx in advance
cool site BTW
- The Milkman
Re: bypassing the cutout diode pack on a KZ550
18 Nov 2005 14:09
Welcome to KZRider. If you are trying to bypass the kickstand switch is should be simple. If it has just one wire going to it, it probably just make a connection to ground when the kickstand is up. Just connect the wire to ground in this scenario. If it has 2 wires try just connecting them together.
Ride safe,
Les
Oh, btw, go to the New Members forum and put a post up.
Ride safe,
Les
- woodz
19 Nov 2005 03:46
thanks m8
if it was my bike i would of had a go but i didn't want to blow someone elses up!:lol:
- Duck
- e vica na i sau na ga
19 Nov 2005 04:35
Not familiar with specific application but...
Suspect it's a proximity switch and 'stand up' allows diode to conduct to ground(earth). Look at circuit and for a clue as to where to place your new ground. Personally, I would make it work. I wouldn't want to start bike and have it take off without me. I am somewhat absent minded at times.
-Duck
-Duck
- woodz
19 Nov 2005 06:15
dunno about the guy who owns the 550 but i personally pull the clutch in when i start a bike and look down to see if the side stand is up before i ride away so don't rely on these switches being there..
BUT the wifes GPZ def needs them! its so easy to knock the little F**ker into gear putting the stand down.. we have quite a performance storing our bikes which requires a far bit of moving the bike and getting off with the engine running..
