timing marks for kz750B
- DaytonaFreakBoy
29 Oct 2006 14:32
hey gang
bike has a bit of a splutter when on the throttle at mid - high rpms..
has backfired a couple times when tryiong to start it as well..
im replacing my plugs as soon as i finish posting here, and the points look like they are just about brand new..
so , im thinking i should go ahead and double check the ignition timing -just wondering what timing marks i should look to line up at idle , and advance..
thanks a bunch! Al
thanks a bunch! Al
- Biquetoast
- King Jeremy The Wicked
Re: timing marks for kz750B
29 Oct 2006 14:39
I just want to plant somewhere in the back of your mind....: it could be a failing coil....
But as to your timing question, I have a question for you: Do you have a service manual? Honestly I'm so pathetic I don't remember the marks, but there's a mark for ~1000rpm (idle) and a mark for ~3000rpm (full advance)....memory loss...:blink:
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- steell
29 Oct 2006 15:02
"F" mark at idle and the two lines at 3900 rpm.
Check coil, spark plug wires, and spark plug caps. ~17k ohms between the two spark plug wires, and ~3-4 ohms between the two small wires that attach to the coil.
Post edited by: steell, at: 2006/10/29 18:04
- DaytonaFreakBoy
30 Oct 2006 22:10
replaced the plugs and tweaked the timing, all that popping and spluttering is history..
thanks fellas
thanks fellas
