Dyna S install
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: Dyna S install
28 Feb 2008 12:36
#197404
I'm looking to purchase one of these now for my 650. Did anyone ever hear if Dyna switched the wire colors?
The Kaw List:
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: Dyna S install
28 Feb 2008 12:40
#197406
I bought two in 2007 and both were correct. I got them through my neighbor who got them from a racing supply place.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • pumps
  • pumps's Avatar
Re: Dyna S install
28 Feb 2008 18:38
#197439
I ordered one last summer from Z1 with new plug wires and coils and it was right. No problems.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Dyna S install
03 Mar 2008 06:01
#198103
Got mine last year and wires were correct, must have fixed thier "production" problem.
Re: Dyna S install
03 Mar 2008 07:48
#198117
On Z1, KZ900 and KZ1000, under the points cover should be located either a leftside and rightside set of points or a leftside and rightside ignition module.
With a correctly installed rotor, the leftside points or leftside module triggers the leftside ignition coil (located underneath the fuel tank) which fires the outside sparkplugs #1 and #4, and the rightside points or rightside module triggers the rightside ignition coil (located underneath the fuel tank) which fires the inside sparkplugs #2 and #3.
The wire color is of course immaterial so long as it connects to the correct ignition coil. But having correct codes in the installation instructions would indeed save some confusion and aggravation.
On some bike models, the ignition coil roles are reversed so that leftside ignition coil fires the inside sparkplugs #2 and #3 and the rightside ignition coil fires the outside sparkplugs #1 and #4.
Sorry if this is all duplicative information. :)
Post edited by: Patton, at: 2008/03/03 12:56
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
Re: Dyna S install
03 Mar 2008 09:11
#198128
I remember when I did mine 14 years ago I had the same problem and was stressed out thought I had followed the instructions wrong until my neighbor veteran Kaw man told me I installed everything correctly but that it was wrong because the instructions were backward and five minutes later I got her going. Still in the back of my mind I was worried that something wasn't right. I am glad they made sure to write the instructions and color code the wires correctly finally.
79 LTD B3
  • loudhvx
  • loudhvx's Avatar
Re: Dyna S install
03 Mar 2008 11:49
#198160
Sorry if this is all duplicative information. :)<br><br>Post edited by: Patton, at: 2008/03/03 12:56
Well said.
This is duplicative, but should be duplicated often since the question arises often! :)
