new wiring harness help
  • auggiedog
  • auggiedog's Avatar Topic Author
Re: new wiring harness help
24 Oct 2006 17:35
#86974
you know, it's funny but yet still informative to see you guys keep going on a subject long after I have my answer~!:laugh:
It sounds like it is similar to lighting dimming systems that send control signal over the same line as power supply....
Thanks again, I'm sure I might have more questions later...:whistle:
K
  • loudhvx
  • loudhvx's Avatar
24 Oct 2006 22:41
#87089
wiredgeorge wrote:
Hmmm... I wonder about the sense coming from the battery. The battery's condition and the fact that its output is the direct result of the reg/reg feed seems to make it a poor cantidate for providing the sense info. I guess they know what they are doing since they are about the biggest aftermarket manufacturer. Thanks for the explanation!
The brown sense line is meant to sense battery voltage. The red output wire from the regulator also goes to the battery. They go to the same place... the battery.
If anything, the brown wire would be a worse place to sense the battery since it takes a longer path.
The only real difference is that the red wire does not get switched (which makes it a better indicator of actual battery voltage).
Post edited by: loudhvx, at: 2006/10/25 01:43
