Kick stand switch trippin.
- Sweet Back
19 Oct 2006 12:28
Alright, so came off the freeway and the bike started buckin like no gas. Long story short, figured out the bike thinks the kick stand switch is activated. When I put it in gear, it shuts off. I pulled the fuse and the bike runs fine, but no signals and other stuff connected to that fuse. Had another switch around, tried it. No luck. Do I just need to trace the wiring or is this a known issue with a known fix? The wires go into the bundle and I hate tearing that apart. Thanks all.
- Biquetoast
- King Jeremy The Wicked
Re: Kick stand switch trippin.
19 Oct 2006 13:25
I'm confused - how does the fuse affect a kill switch?
If it *is* wiring, I always start my troubleshooting with a visual inspection, looking at bends and places that might get worn/bent over a suspension part or something, like around the headstock where lots of wires flex.
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- OKC_Kent
19 Oct 2006 14:00
You can try cleaning the kickstand switch to get it in working order.
Or I would cut the switch out and connect the wires. Problem solved.
Kickstand Switch?!?! We don't need no stinkin' kickstand switch!!:lol:
Cashion, OK
78 KZ650 B2 85,000+ miles
- pumps
19 Oct 2006 15:04
I had that issue with my Virago. Since it sat outside in the weather for a whole year on the side stand when I bought it, it thought the sidestand was still down.Put it in gear it would die. Took the switch apart, sprayed some contact cleaner stuff I use called De-Oxit on the contacts, little rub with a soft wire brush. Put it back together and it has worked perfectly.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- hmondo
19 Oct 2006 15:35
I've used electrical contact cleaner on mine and it worked for a while. I ended up replacing it because it still continued to fail. I would suggest just replacing just to be safe.
1989 KZ1000 P-8 (Police)
1987 ZL1000
1986 Concours (Project Bike)
1987 ZL1000
- Sweet Back
20 Oct 2006 02:39
Fixed. I did try another switch but that one had been sitting. I just cut the wires, connected them to each other, done. I ALWAYS check my kick stand, habit. So, I'm not worried. Thanks all. Another caper closed by the KZ riders, love it..
- arobsum
21 Oct 2006 10:35
Sweet Back wrote:
i was going to suggest you bypass the switch but you beat me to it!Fixed. I did try another switch but that one had been sitting. I just cut the wires, connected them to each other, done. I ALWAYS check my kick stand, habit. So, I'm not worried. Thanks all. Another caper closed by the KZ riders, love it..
