Rewire
- Sloth_Man
Rewire
18 Oct 2006 21:29
Hi i have a 79 kz100 and most of the wiring is corroded. How hard is it and how costly to rewire whole bike?
- wiredgeorge
Re: Rewire
19 Oct 2006 06:10
Depends on your understanding of bike electrics. I suspect that after you bought the wire and connectors, shrink wrap and solder and other supplies, it might be just as easy and cost effective to buy a new wiring harness. I believe
www.z1enterprises.com
sells new replacement wiring harnesses. If you buy a good used one from eBay, I strongly suggest you get one from the same year and model as even small changes can be a challenge if you are not real good with electrical stuff. Most people talk about a bike having tons of extra wiring that really isn't needed but then want to use turn signals and headlights/tail lights and such and find that there isn't a lot of extra wiring... A lot of folks ask for "bare bones" wiring diagrams but are never heard of again bwhahaha
- cb_eric22
Re: Rewire
19 Oct 2006 18:29
I am considering this too. I have a 79 KZ650SR, and was thinking of possibly redoing the wiring, cleaning it up, stuff like that. I'm fairly good with electrics and wiring. Any suggestions?
- 77KZ650
Re: Rewire
22 Oct 2006 22:43
cb_eric22 wrote:
get the same colours!!! that way it will still be colour coded and you can still use the factory wire diagrams;) it would be pretty hard to hook up a bunch of stuff if it was taken apart again and everything was one colour....I am considering this too. I have a 79 KZ650SR, and was thinking of possibly redoing the wiring, cleaning it up, stuff like that. I'm fairly good with electrics and wiring. Any suggestions?
07 MDP Rookie of the Year
