ignition/charging system up grades for the 750B twin??
  • DaytonaFreakBoy
  • DaytonaFreakBoy's Avatar Topic Author
12 Oct 2006 23:06
#83839
is there a simplified wiring diagram floating around for the kz twin?
i read something about dumping " ballast resistors "... the less systems/parts that can fail - the better
anybody know if there is an electronic ignition made for these old two lungers?
whats the hottest coil set up for these bikes??
and.. whats the best brand ( and source ) for an updated reg/rectifier ?
been a while since i felt like such a newbie
:blink:
  • steell
  • steell's Avatar
Re: ignition/charging system up grades for the 750B twin??
13 Oct 2006 03:42
#83847
I don't know of one
No ballast resister on any year 750 twin.
I think the Boyer Bransdon (or something like that) is still available.
82-83 750 twin stock electronic ignition will fit the earlier models.
KZ440 stock electronic ignition will fit the 750 twin also.
Accel or Dyna
Depends on the year of 750 twin, 76-77 use one type of charging system while the 78-83 uses a different type.
New regulators and stators are available from Rick's or Electrex for the 78-83 models, best idea for a 76-77 is to update it to the 78-82 style (requires replacing the stator, rotor, engine cover, and reg/rec with later style parts).
Everyone is a newbie at first :)
  • mariozappa
  • mariozappa's Avatar
13 Oct 2006 05:17
#83860
I'm glad this came up.
I'm trying to sort out my twin too.
I was told it had a bad stator when I bought it.
It came with another stator, and from kawasaki.com , it looks to be the newer type with the cover and all.
I haven't checked the regulator yet (that's next).
She runs, now she just needs to charge!
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
13 Oct 2006 05:22
#83864
I want to take a stab at a couple of these, too...
What do you mean by "simplified"? More simple than what's in the Kawasaki Service Manual or the Owner's Manual?
Just to clarify, its the Boyer Brandsen, and yes it is still available. Also, besides the other Steell mentioned, there are still a few Newtronics floating around out there. See these links:
Link to Newtronics
A PDF about "Newtronics Under New Ownership"
An example of where they can still be bought
A good thread on this topic over at Ivar's KAWASAKI TWINS forum
Not sure about "hottest" since I'm no expert, but I got a Dyna Dual Output 3.0 Ohm Coil DC1-1 from z1Enterprises.com and it is great. Might be the best upgrade I made to the bike, and there have been many.
Again, I got this regulator/rectifier from z1Enterprises.com. There are others out there to be sure, and you can certainly get one from eBay, but that was one item I just didn't want to mess with... after blowing up all the bulbs on the bike... ;)
I'm *still* a newbie....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • steell
  • steell's Avatar
13 Oct 2006 17:19
#84054
It's "Boyer Brandsden" according to This site , so I guess we were both wrong :D
We could argue about who was closest though, if you want :laugh: :laugh: :laugh:
76-77 KZ750B cover has 3 screws around the center to hold the stator, and they are visible on the outside. To switch over you need the stator, cover, rotor, and reg/rec.
Post edited by: steell, at: 2006/10/13 20:23
  • agawam
  • agawam's Avatar
13 Oct 2006 21:05
#84148
well I'm a gonna be needin some wirein also. I had the electrics on my twin flame up today, melted the coil, shorted the lights and god knows what else, I guess thats what winter is for
  • agawam
  • agawam's Avatar
13 Oct 2006 21:26
#84157
Isn't the wire harness from a KZ400 the same as the 750B, in fact wouldn't most of the twins of that era be just about the same, I have two 305s for parts
  • steell
  • steell's Avatar
13 Oct 2006 22:00
#84166
I doubt it, I know the KZ440 harness is quite a bit different because I have one I use for parts.
What year is your 750? I might have a wiring harness (77 and 78 I think}.
  • agawam
  • agawam's Avatar
13 Oct 2006 22:24
#84168
Mine is a 79, the wireing was a bit funky when I got it, I took apart most of the connections and cleaned them up but there has always been something not quite right, I'm not afraid of it just another thing thats going to be done I guess, if you have a harness that would be great,I have four I'm doing now and time is at a premium, I have a ton of 650 and H1 parts but only the one 750twin
