solid state reg/rect
- amedeo
15 Nov 2005 05:33
on my 77 Kz400,i have a shorted rectifier. this is the old type with the separate voltage reg. I have a newer solid state reg/rec combo.it also has 3 wires coming out plus the fourth that goes to the battery.my question is this ,one wire is black the other two are yellow. can i change the connector head and use it ,or do i have to change the stator? thanks to all.
- loudhvx
Re: solid state reg/rect
15 Nov 2005 10:06
Sounds like it's the wrong type of reg/rec combo.
Ibsen will know better, but I think your bike uses an excited-field alternator. The reg/rec combo would need the same number of yellow wires, plus a ground wire, a positive wire, and a wire to the rotor. Some combos also have what's called a sense wire (usually brown).
Where did you get the reg/rec combo, and/or what bike was it intended for?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- guitargeek
15 Nov 2005 11:20
Solid state... as opposed to tube powered?
Sorry, just had to ask...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- steell
15 Nov 2005 16:26
guitargeek wrote:
You spend too much time with amplifiers :laugh: :laugh:
Solid state as compared to mechanical (regulator).Solid state... as opposed to tube powered?
