750 wire harness work?
- steveo_4192003
- 77kz650b-1
30 Sep 2006 12:07
i got a parts bike and wanted to know if the wireharness will work on my mangled-up mess of wires on my 77650b-1.
the parts bike is a 1979 kz750h all stock/no motor.
but it has a good harness on it. is there any other parts work such as headlight ect...
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- steell
Re: 750 wire harness work?
30 Sep 2006 15:19
KZ750H would have to be an 80 or newer model and with electronic ignition.
If you got the complete bike then you should be able to make it work, even use the 750 ignition switch if needed.
Post edited by: steell, at: 2006/09/30 18:20
- steveo_4192003
- 77kz650b-1
Re: 79' 750 wire harness work on 77' 650b-1?
30 Sep 2006 18:28
the info card (on frame) says # kz750h000518 8/79 but probally came out in 80'
thanks for your help! i may just use that ignition switch to!
- loudhvx
01 Oct 2006 19:20
Steell, does the KZ750H have the same charging system as the 77 650? That's the three-phase one with a field-coil and two-piece reg and rec.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- steell
02 Oct 2006 03:35
Nope, 750H uses a permanent magnet alternator, no coil, but you can swap the rotor, stator, sidecover, and reg/rec, onto your 650. Makes using the 750 wiring harness easier.
