78 KZ 650 start trouble
- wiredgeorge
Re: 78 KZ 650 start trouble
30 Oct 2006 18:58
It sounded like his IC Igniter smoked. There is no CDI ignition on a 650... The IC Igniter connects to pickup coils under the right side points cover. The IC Igniter also hooks to your coils. Put your bike year/model and your location in your signature. If some kind KZRider member is nearby, they might be able to help.
- DaytonaFreakBoy
30 Oct 2006 22:22
the initial problem you described where it wouldnt do much until hooked up to cables on your car sounds like a bad ground.
been there doen that , and it drove me nuts until i figured it out... that ground was one of the last things i checked, and since that particular experience - its now one of the first things i look at any time i have a bike with a good battery that is still suffering from a slow starter or weak/erratic voltage
sounds like you need to sort your wires and any other issues as a result of smoking the electrical system with those jumper cables ( sorry to hear that too man, i think everybody has mucked something up trying to fix it at some point in their lifetime )
BUT , i am willing to bet that if you clean up the ground for your battery.. at the terminal and the frame , that will take care of the initial problem. good luck bud , Al
Post edited by: DaytonaFreakBoy, at: 2006/10/31 01:23
Post edited by: DaytonaFreakBoy, at: 2006/10/31 08:15
