Dyna ignition, where to set timing?
  • KenC
  • KenC's Avatar Topic Author
12 Nov 2005 23:06
#7995
I just installed a Dyna electronic ignition on my 75 Z1 and I am curious where the indicator should be pointing. At Idle I am assuming it should be on the "F" mark? Then move to the advance mark at higher RPM's? Is this correct?
Thanks,
Ken
  • RonKZ650
  • RonKZ650's Avatar
Re: Dyna ignition, where to set timing?
13 Nov 2005 09:11
#8028
Correct.
Thanks,
Ken
  • Garn
  • Garn's Avatar
14 Nov 2005 02:38
#8103
Ken, did you use the original Z1B coils? There is something about they must be more than 2.5 ohms or something like that, I was wondering how your coils measured up? I never know where you measure and is the resistor in the spark-plug cap, counted in the measurement?
Regardz.
Just something to keep you awake all night!
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
