Stator resistance testing
- kzmason
25 Sep 2006 09:15
can you test it with it off the bike? I am getting a fairly even resistance with between all three wires of about 1.1 with it off the bike ..?
- loudhvx
Re: Stator resistance testing
25 Sep 2006 11:12
You can only resistance test it off the bike. That doesn't mean it can put out the power that is required, but it's a good test to start with. Yours sounds about right. Does it show continuity to the frame of the stator? It shouldn't.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- kzmason
25 Sep 2006 16:31
I'll test the continuity thing, good idea. The book says .45-something less than one and that above that the stator should be replaced..?
- kzmason
28 Sep 2006 08:55
I did the contiunuity test to the body from each wire and got nothing. Sweet. So, why does the book say that resistance above .5? the stator should be replaced?
Post edited by: kzmason, at: 2006/09/28 11:55
- loudhvx
01 Oct 2006 18:43
I wouldn't think it needs to be replaced just yet, especially if all the readings are close to one another.
1981 KZ550 D1 gpz.
Other links.
Other links.
