idiot light help
- unkle fester
idiot light help
24 Sep 2006 18:24
78 kz650b neutral light, oil pressure light and brake trouble light do not work...BUT...between the OFF and On...and ON and Park posistions on key switch, the before mentioned idiot lights will flicker...I tested continuity of switch per the manual...they all have in common a brown wire on one side of these lights...any help would be greatly appreciated....thanks
- KZQ
- Administrator
Re: idiot light help
24 Sep 2006 19:25
I'm not really familiar with your exact model BUT check the ignition harness wherever it may be forced to flex because it's secured to the frame or to the back of the ignition switch itself. These points often concentrate the bending of the wiring harness and cause intermittant opens in the circuit.
KZCSI
Post edited by: KZCSI, at: 2006/09/24 22:26
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- apeman
25 Sep 2006 09:56
I agree with KZCSI, butsuggest you also disassemble, inspect and clean the contacts in your ignition switch. It sounds to me like something inside there may be out of alignment.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- unkle fester
02 Oct 2006 14:12
UPDATE.....nothing....tried new ignition switch, checked continuity from oil pressure sending unit, neutral switch, and brake trouble switch to 9 pin connector in harness going to these lights....as earlier stated they will briefly flicker between off and start posistion on ignition switch...but that's it..the only thing they have in common is a brown wire that they all connect to..have checked continuity everywhere the wire terminates.......HELP!!!!...thanks
