Running lights?
- IowaKZ
- '80 G1 Classic
Running lights?
22 Sep 2006 13:28
I have a 1980 kz1000G. Is this bike supposed to have running lights on the rear signals?
I know that the front turn signals are also running lights, but are the rear also?
I am guessing not since the wiring diagram doesn't show any like it does on the front.
Thanks.
Thanks.
1980 G1 Classic
Bettendorf, Iowa
Bettendorf, Iowa
- Biquetoast
- King Jeremy The Wicked
Re: Running lights?
22 Sep 2006 16:03
IowaKZ wrote:
Front running lights (1157), rear turn only (1156).
This is a common question... The answer is no.I have a 1980 kz1000G. Is this bike supposed to have running lights on the rear signals?
Thanks.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- rstnick
Re: Running lights?
22 Sep 2006 18:02
You could get a set of front, 3 wire signals and put them on the back. Then run the third wire from the front to the back, and you have running lights at all four corners. I did that a number of years back.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- floridamba
- rstnick
Re: Running lights?
22 Sep 2006 18:15
I think I remember some saying it was not legal in their area, so best to check it out first. You may be able to get by with red lens covers.
I used the stock amber ones for 10 years in Toronto, and never had a ticket. Sure was quite a bit brighter at night too.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- apeman
Re: Running lights?
23 Sep 2006 13:41
If you install the two wire set-up in the rear you can become legal if you use red lenses in the rear lights. That way you have only red lights showing in the rear. I think you can get red lenses from some aftermarket sources.
Also, you might need to up the size of your fuse to allow for the increased current.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
