1979 kz650sr ignition switch
- ridgerunner
21 Sep 2006 20:42
Ok guys I need an electrical person to help me out on this one. I have a 1979 650sr that is in dire need of an
ignition switch. I can't find anything that matches mine,even tho a lot are advertised as being the same. I did buy a switch for a 1978 but it is diffirent. Ok heres the deal. The '79 harness has a yellow lead and the brown wire bypasses the switch. The 78 switch has no yellow and has a brown lead on it. Question: How do
I make the '78 switch work. I found wiring diagrams on both models on this site but i can't figure it out.
Thanks for your help.
This is a great site.
1982 550kz ltd (great bike)
1979 650kz sr (hopefully will be a great bike)
- pumps
Re: 1979 kz650sr ignition switch
23 Sep 2006 22:23I did buy a switch for a 1978 but it is different
Just for clarification ,when you say you bought a 78 switch, you mean a switch for a 78 sr?
I haven't look at the diagrams but I do know the bike won't know the difference in colors, can't you just plug the brown lead into yellow on the harness?
Ok Ive looked at the 79 D2 diagram which is what my 79 sr is..what is the 78 off of, a 78 650 what?
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- rstnick
24 Sep 2006 06:57
Welcome.
There are a few different '78s.
Here is my make on it:
1: Your green/orange goes to '78 ign's green/orange
2 whites go to 2 whites
red to red
blue/red to blue
yellow to brown
brown spliced into Green/orange to give power into the brown circuit when turned on.
2: I also think your Yellow and Brown could both go to the 78's brown, as both ways (1 & 2) would power up both circuits.
Have some spare fuses ready in case I'm wrong. :pinch:
Anyone else want to try a stab at it?
Post edited by: rstnick, at: 2006/09/24 09:59
red to red
blue/red to blue
yellow to brown
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- ridgerunner
24 Sep 2006 07:15
I bought the switch from ebay and the guy said it was from a 650kz. I didn't know the model.
Thanks
Thanks
- ridgerunner
24 Sep 2006 07:18
Thanks for the reply. I will try your suggestions and see what happens. I'll keep you posted.
82 kz550ltd
79 kz650sr
71 triumph 650
82 kz550ltd
79 kz650sr
71 triumph 650
- ridgerunner
24 Sep 2006 17:17
Ok plugged the brown into the yellow and jumped the brown to the brown start sw. Everthing seemed to be fine and then I hit the start button a couple of times and the starter worked. The third time I tried the starter worked but the lites got real dim and wires started getting hot. Must be a dead short somewhere in
the thing. I unplugged the point and ignition leads from the coil and lites got bright again. Now the starter will not kick in. Any ideas would be appreciated.
1982 kz550ltd-fine bike
1979 kz650sr-work in progress but running out of patience
1971-triumph 650 ok bike but shifts and brakes on the wrong dern side.
- rstnick
24 Sep 2006 17:22
Clean the starter button with electrical spray contact cleaner.
I find I sometimes need to press the starter button and hold and wiggle it around before it makes contact and works.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
