melting wires
- 1stkz650
- 1stkz650
- 1stkz650
- Six9GS
Welcome to this wonderful place. I don't have any magic cure answers to this one. Sounds to me like you will need to get ahold of the wiring diagram (which is probably available under the KZ Information tab of this web site) and then methodically figure out the problem. Sounds to me like something wierd is going on with your charging circuit. Personaly, I'd start there. Step by step, one wire, circuit at a time hopefully will lead you to discover the culprit(s) to this dilemma. There are lots of people with 650 experience on this site. So, if you have questions about how to check specific things and such, first try the forum search. Highly likely that it has been posted before. Or, just ask away.
On my 78 kz650 the two blue wires underneath the tank are for a gas gauge that is not on the USA version. So, connecting them, not connecting them doesn't matter. They are not used, unless you have a sensor thingy installed in your gas tank. I don't.
Best of luck to you. Welcome aboard!
Terry!
- 762shooter
your voltage regulator is hooked up correctly.
I just went through the same thing on a Z1 900,
the yellow wires, where the coil power wires split,
were getting so hot they were melting and frying
the ignition. On this one the Rectifier was not
even hooked and the Voltage Regulator wasn't hooked
up right, who knows how many volts the system was
getting.
- wiredgeorge
- 77Davo650
- Thank you received: 4
What I did was re-wire the entire bike and replace the rectifier, now it's good as new.
Hope this helps. Re-wiring wasn't too fun, but now it's all brand spankin new
If your reg/rec is still good, replace the burnt wires and clean all the connections and you should be good, but make sure that the melted wire didn't fuse with other wires within the harness, that's no fun.
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
- MyKz650
- Gunpowder and Gasoline
I have a ?? What kind of wire did you use? I mean did you use the generic autoparts wire or did you find the stuff that was striped kind of like the OEM? I want to rewire my 650 and upgrade the whole harness
1978 KZ650 C
*NEW* 1980 Z1000 G1 Classic
- 1stkz650
thanks
