82 kz1000m ignition switch solder
  • squints
  • squints's Avatar Topic Author
19 Sep 2006 05:37
#77772
Ok, I've been documenting my ignition problems on this board and I finally have some pics. I've been soldering the white wire to the point I think it is supposed to be connected to, but now I'm not so sure.
Let me know what you all think. What point should this wire be soldered to. I have been attaching it to the point above, the more silver one. But am I wrong and shold it be attached to the lower more bronze colored one?????
Post edited by: squints, at: 2006/09/19 08:38
Post edited by: squints, at: 2006/09/19 11:31
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
  • squints
Re: 82 kz1000m ignition switch solder
20 Sep 2006 06:26
#78112
any help?
Upstate NY
  • squints
20 Sep 2006 06:28
#78113
the wires melted together a bit when the power wire was coming loose, that explains the discoloration and lack of insulation material.
Upstate NY
  • wireman
  • wireman's Avatar
20 Sep 2006 06:37
#78116
i dont have a csr to compare notes with.:(
  • OKC_Kent
  • OKC_Kent's Avatar
20 Sep 2006 06:52
#78120
In our filebase section someone has uploaded a wiring diagram for a 1982 KZ1000M2. Maybe it will help you.
Post edited by: OKC_Kent, at: 2006/09/20 09:58
Cashion, OK
78 KZ650 B2 85,000+ miles
