82 KZ turn signal question?
- _CrazyHorse_
18 Sep 2006 17:39
Since I have owned my bike the rear turn signals have never worked unless the turn signals are on. I don't know if they are supposed to or not while regular running or not. So I thought I would relocate the lights and when I took off the rear light I thought I would test it to see if it would work and neither one would work. They would both work when the hazzard lights were on. Could I have overlooked something?
- DawnKZ750
Re: 82 KZ turn signal question?
18 Sep 2006 21:54
They don't "light up" steady. They should blink when you switch on the turn signal. The front ones should stay (steady) on - but not the rear.
Dawn
Dawn
1982 KZ750-E
MASSACHUSETTS
MASSACHUSETTS
- JMKZHI
Last edit: 03 Dec 2008 17:02 by JMKZHI.
- bemoore
19 Sep 2006 11:58
JMKZHI wrote:
Did this change sometime between 77 and 82? The front signals on my 77 (which are not stock) only work as directionals.The front turn signals kinda serve as running lights
77 KZ650C1 w/Kerker 4-1
- JMKZHI
Last edit: 03 Dec 2008 17:03 by JMKZHI.
- _CrazyHorse_
19 Sep 2006 16:14
I cleaned off the flasher and scraped away piles of rust. Plugged it back in and they worked. Thanks fellas.
