What is \"P\" for?
- mike fitzwell
What is \"P\" for?
11 Nov 2005 09:12Please Log in or Create an account to join the conversation.
- mariozappa
Re: What is \"P\" for?
11 Nov 2005 09:56
P is for park.
when you put the key in the ignition and turn it to P, your tail light should come on. I believe it is that way for safety. But I didn't figure it out until not too long ago.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- loudhvx
11 Nov 2005 09:57
Parking light.
It's the same as "lock", but the tail light should stay on as a parking light.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- RonKZ650
11 Nov 2005 10:02
Like mentioned it is for "park". I'd recommend to not use it. For some reason a lot of the time the switch will turn easily to park, then not turn back the other way so you are permenantly "parked". No fun.
- loudhvx
Re: What is
11 Nov 2005 10:25
RonKZ650 wrote:
That reminds me of the time my friend's RD400 broke a clutch cable then, almost at the same time, the kick stand fell off from vibration. He looked at me and said "damn, I can't ride it, and... I can't park it. I'm screwed!"
1981 KZ550 D1 gpz.
Other links.
Other links.
- JR
Re: What is
11 Nov 2005 11:02
I found out the hard way what "P" stands for when I switched to P one evening, removed the key and found I had a flat battery the next morning. I just had'nt noticed the tail light on.
Duh !
Duh !
- mike fitzwell
Re: What is
11 Nov 2005 11:05
Yep, just checked when I went home for lunch and it works like you guys said. Not too useful IMO, but at least I know what it does now.
Thanks guys!
Thanks guys!
- mariozappa
Re: What is
11 Nov 2005 11:39
I think it was meant for road side stops. So if you were off your bike for whatever reason, the tail light could stay on with out the engine running to make you more visible to traffic.
1977 KZ650C1
- fergyfer
Re: What is
11 Nov 2005 13:16
I found out the hard way that it doesn't like to leave the park position on my ol 550. I thought I was going to have to unplug the lights fuse. I fought for 20 minutes and finally it let go. Seemed like the locking mechanism was stuck. Then I tried the "lock" position, the one in the opposite direction with the key. You would think I would have learned already, but no. I thought I would spend the rest of my life driving in circles after fighting with it for another 20 minutes. Finally came unlocked. Believe it or not, I never tried it again. ha!
- wiredgeorge
Re: What is
11 Nov 2005 13:20
Remember how you adjusted your handlebars... if you ever lock the forks, all you have to do is put the wheel up against some solid object and give the bars a good yank and you will no longer be bothered by that pesky steering lock bwhahaha
- GargantuChet
11 Nov 2005 14:04
Not sure about other bikes, but my flashers (turn signals and hazard lights) also work in that position (without the key).
