blinkers randomly blinking
  • requiem
  • requiem's Avatar Topic Author
12 Sep 2006 13:42
#76158
hey, my blinkers are blinking at a random rate, why?
  • ambergrismooon
  • ambergrismooon's Avatar
Re: blinkers randomly blinking
12 Sep 2006 15:36
#76176
I once heard it was cause of some butterfly in some rain forrest somewhere.
Are they stock directionals? Check voltage and resistance. Sometimes resistance is futile. I am sorry I couldn't resist.....see!
  • kawsakiman
  • kawsakiman's Avatar
12 Sep 2006 16:36
#76188
i think you got either a intermitten ground or a bad flasher
  • requiem
12 Sep 2006 19:42
#76233
haha. you made me laugh, even if you didn't help. preciate the second comment - i'll check the intermittent ground idea.
  • tw..
  • tw..'s Avatar
14 Sep 2006 07:25
#76658
when i had this problem on my 76 KZ900 i replace both flashers with the heavy duty replacement flashers from auto zone which solved my problem.
tom
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • requiem
14 Sep 2006 09:47
#76702
thanks!
  • wiredgeorge
  • wiredgeorge's Avatar
15 Sep 2006 12:58
#76991
The turn signals on both the front and back on your KZ1000A1 have a strange ground system. There is a metal ring that fits under the mount bolt to provide ground and this ring has a wire (black/yellow) soldered onto it. The wire then plugs into the wiring harness ground which grounds to the engine case. Since the ring sits in a place that is often plauged by oxidation, ground can pretty easily be broken and MANY Kaw turn signal issues are just the result of a poor ground. Check the grounds on all four signals. The turn signal relay itself is prone to failure. A heavy duty relay doesn't last any longer but allows a wider range of voltages in the event you are not using OEM type bulbs (Stanley specification). Relays can be had at any autoparts store.
  • requiem
16 Sep 2006 08:24
#77157
nice. i remember that now that you mention it, i lost a ground that way a couple years ago. appreciate it!!
  • KZ250LTD
  • KZ250LTD's Avatar
16 Sep 2006 20:52 - 07 Jun 2009 13:39
#77324
79 KZ1000ST
Past:
Many.
Last edit: 07 Jun 2009 13:39 by KZ250LTD.
