dyna lll or not ?
  • woodyskz
  • woodyskz's Avatar Topic Author
dyna lll or not ?
09 Sep 2006 17:52
#75544
Should I go w/ the dyna lll model # D32-2, or should I go w/ the DS2-2 that comes without the module to mount
? Are one of these kits newer design, upgrade, ect. Thanks for the advice. '77 KZ650c bone stock.
  • Six9GS
  • Six9GS's Avatar
Re: dyna lll or not ?
09 Sep 2006 19:27
#75556
My question concerning this would be what do you want to use the bike for. If you only want to putt around on it and not really race and such, I think I would go for the Dyna S. The Dyna III allows for more flexibility. But, it seems to me you only really need or use that flexibility if you are going to be racing it. At least that was my thoughts when I was looking into putting a Dyna system on mine.
That's my $0.02 worth. Good Luck to you!
  • loudhvx
  • loudhvx's Avatar
09 Sep 2006 23:22
#75584
The DynaIII and Dyna-S are functionally about the same. They both use a hall-effect sensor with fixed dwell angle (a little over 300 degrees). Both use the stock advancer on which you install a magnetic rotor.
The difference is that the DynaIII puts some of the more critical electronics in a remote box. This would be more reliable, but costs more so Dyna discontinued the DynaIII in favor of the more econimical Dyna-S.
The Dyna 2000 and Dyna 3000 give you adjustable electronic advance curves and rev limiters.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
10 Sep 2006 04:51
#75595
If you can find a good dyna 3 for as much less than the S, as you value the S warranty, I'd recommend the 3. For me this would be about half price. $60 kept in the pocket is always a good thing ;-). Another option is 'eletronic points' and ignition module from a later model bike. -Duck
  • woodyskz
10 Sep 2006 13:48
#75689
Thanks for the tip Duck, what year & model could i find the elect.points & module that will iterchange w/ the stock point/cond. setup ?
  • woodyskz
10 Sep 2006 13:52
#75691
Thanks again for the deciding info loud.
  • woodyskz
10 Sep 2006 13:56
#75694
she's a stocker six, no raceing on this one. Thanks for the reply .
  • Duck
  • Duck's Avatar
10 Sep 2006 19:34
#75792
Sorry, I do not know year and model for 650. Have police bike parts on the 900 project motor. Maybe search of archives would find. Try google too. -Duck
  • loudhvx
  • loudhvx's Avatar
10 Sep 2006 22:50
#75818
You could try to get an electronic ignition from a 650, 750 (4cyl), or a 550. They were available from about 1980 to 1984 depending on the model. Later than that reportedly won't fit.
You'll need the rotor, pickups, ignitor, and possibly coils. Points-coils may work if your bike is stock and in good condition, but they will produce less energy in the spark compared to the electronic-ignition coils.
However, you will probably end up paying more than you would for a Dyna S.
  • Duck
  • Duck's Avatar
11 Sep 2006 03:43
#75831
Good to know. Thanks. Curious about coils though. The factory ignitor should have enough dwell to give the same spark as the points did. Not being in a hurry helps. Got a pickup for a police engine with rotor and nice clean advance unit for $6 plus $5 ship on ebay. Need to start looking for the ignitor ;-). Start cutting and welding in 4 weeks.
-Duck
  • loudhvx
  • loudhvx's Avatar
11 Sep 2006 09:45
#75887
Points had a fixed dwell of about 180 deg (crankshaft), if I recall.
The electronic dwell increase from about 100 deg to about 120 deg.
So it's not a big difference, and is really only a factor at high RPM since 100 deg is way more than enough at idle. The difference is about 1 milli-second at 10,000 RPM. But to a coil, 1 millisecond may make the difference in firing or not.
Also, on the electronic ignitions, by "later" ones, I mean the ones with electronic advance. They reportedly won't fit into the older engines. They can easily be identified since they have no mechanical advancer, and the pickups are on a big bracket looking thing instead of a round timing plate.
Post edited by: loudhvx, at: 2006/09/11 12:49
