weird ignition prob
- DemonSpeed
weird ignition prob
03 Sep 2006 16:00
sup guys im building a custom chopper using a kz900 and a dyna III ignition... well i got it all wired up like how Dyna suggests.. and when i turn the ignition there is no spark... but when i turn the ignition off there is a spark..while having the spark plug out and grounded to a bolt. i made my own harness and wired the ignition just how it should be and it seems like the coils are getting power when they are not supposed to
Post edited by: DemonSpeed, at: 2006/09/03 20:22
- steell
Re: weird ignition prob
03 Sep 2006 18:34
When you turn the ignition on, there should be no spark, and when you turn it off, it should spark.
Think of points systems, when does the coil fire? When the points open and stop current to the coil. When you turn the key on, the coils get power, when you turn it off, the coils magnetic field collapses, which generates current in the secondary side of the coil, which discharges by jumping the gap at the plug.
- DemonSpeed
03 Sep 2006 20:18
what i ment by turning ignition on was acutually turning motor over.... so it is supposed to spark when you turn it the ingnition off? wounder why im not getting spark since the coils are gettin voltage..i
- steell
03 Sep 2006 22:07
DemonSpeed wrote:
Maybe the Dyna is not working right, I don't know as I know next to nothing about Dyna ignitions.what i ment by turning ignition on was acutually turning motor over.... so it is supposed to spark when you turn it the ingnition off? wounder why im not getting spark since the coils are gettin voltage..i
- DemonSpeed
03 Sep 2006 23:44
haha me neither.. im thinkin of throwing the points and ic igniter back in and see if she will fire over
- loudhvx
03 Sep 2006 23:48
Are you sure you have the rotor aligned properly?
The Dyna works by completing the coil circuits all the time until the rotor's magnet comes near the Hall-effect pickup. That's when it shuts off the coil-current by lifting the grond connection. A spark happens as a result, as Steell said.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- DemonSpeed
04 Sep 2006 00:42
i aligned it by specs on dyna website... but it says for 73 and early 74 you have to have a diff rotor and mine is a 74 and i dont knw if i have the right rotor..
- DemonSpeed
04 Sep 2006 00:45
im gonna try the magnet across the pickup to see if it gets a spark tommorow.. we will see what happens
Post edited by: DemonSpeed, at: 2006/09/04 03:53
Post edited by: DemonSpeed, at: 2006/09/04 03:54
- loudhvx
04 Sep 2006 11:34
DemonSpeed wrote:
That should work.
Post edited by: DemonSpeed, at: 2006/09/04 03:53<br><br>Post edited by: DemonSpeed, at: 2006/09/04 03:54
That should work.
1981 KZ550 D1 gpz.
Other links.
Other links.
- DemonSpeed
04 Sep 2006 13:17
well i didnt get anything when i ran it across the plate so im thinkin that its a bad unit
- DemonSpeed
04 Sep 2006 16:27
well i took the dyna out and desided to through the points back in it... does anyone know how the IC Igniter wires up? its for a 74 kz900 and in the wiring diagram on here it shows that the wires off the points plate (two wires green, and black) wire straight to the coils... and then there is a power wire...jumping the two. how does the ic igniter wire up or does this bike not use one?
- steell
04 Sep 2006 16:41
The stock KZ900 was a points system and had no igniter, the points triggered the coils directly.
