77kz650c1 wiring harness
  • slicksilver77kz650c1
  • slicksilver77kz650c1's Avatar Topic Author
26 Aug 2006 20:54
#72734
New member here looking for either a place that sells new wiring harness for 650c1 or other guys with connections, etc., websites that may be able to help me. My silver 650 had its wire harness go up in smoke this morning? Can anyone help me? Ebay seems risky route to go....
  • wiredgeorge
  • wiredgeorge's Avatar
Re: 77kz650c1 wiring harness
27 Aug 2006 05:50
#72754
You can try www.z1enterprises.com - They sell harnesses for the Z1/KZ900 and I am not certain about the 650. These harnesses come from Japan (PMC). I am thinking that eBay will be your best bet. You really need to get the same harness; year and model unless you are a bit electrical savvy as you will end up doing some mods otherwise to make the donor harness work. The MAIN thing is the way the right and left switchgear plug into the harness as well as if the donor harness came from a bike with an on/off switch for the headlight as well as a reserve lighting system and the same exact regulator / rectifier. If these things are not the same, you will need to do some figuring in order to make them work. When you find the correct harness, you can strip the covering off and clean up the wires and check for bare spots or hacks and fix these. I solder and use shrink wrap and then rewrap each harness that I use. After, clean the contacts on the connectors with contact cleaner and dab some dielectic grease on them.
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
27 Aug 2006 20:22
#72904
Hi saw this on ebay it is off a 78 KZ650b but it should work for you current bid is $6.50 with 12 hrs to go. Hurry!
cgi.ebay.com/ebaymotors/KAWASAKI-KZ650-K...QQrdZ1QQcmdZViewItem
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
28 Aug 2006 08:37
#72958
Thanks pal. I am on it. FYI, the local KZ dealer says a new harness would run me $193.00!!! OUCH!!!
  • The Gringo
28 Aug 2006 09:49
#72964
No problem bidding ended at $10.00 hope you got it.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
