Beep Beep - Beep Beep YEAH!
  • squints
  • squints's Avatar Topic Author
22 Aug 2006 11:49
#71599
How do I tell if I have a stock horn or not. The horn on there sounds pretty loud, so I think its an upgrade but how would I be able to tell.
Also, how easy is it to install a second horn. There are two mounts on my frame and it looks like there is space for it. But in terms of wiring, how big of a job is this?
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
  • hwms
  • hwms's Avatar
Re: Beep Beep - Beep Beep YEAH!
22 Aug 2006 12:59
#71614
I would suggest the use of a horn relay.
Hot up the relay with fused wire from battery. Wire the horns to the relay and trigger with the horn button.
  • Nevco48
  • Nevco48's Avatar
22 Aug 2006 13:59
#71624
I had an old horn from a junker, so I put it on my 750 along with the original. I just used longer bolts, with one pointed up and one down. They are wired in parallel, no problems yet, but I don't use it alot...
:laugh: Are you a Beatles fan? "Baby, you can drive my bike..":laugh:
Post edited by: Nevco48, at: 2006/08/22 17:01
  • ltdrider
  • ltdrider's Avatar
22 Aug 2006 14:08
#71627
I think my stock horn is pretty loud.
I didn't used to, but then I fixed the charging system, and with about 14 volts going to it, it's pretty good.
Two horns would be good, but you need to get the right pitch. If they beep at different pitches, then it sounds louder. And more annoying.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • freebyrd24
  • freebyrd24's Avatar
23 Aug 2006 08:02
#71796
my stock horn is obnoxiously loud. i wouldnt worry about it
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
  • JMKZHI
  • JMKZHI's Avatar
Re: .
23 Aug 2006 08:22 - 03 Dec 2008 18:38
#71801
del
Last edit: 03 Dec 2008 18:38 by JMKZHI.
