KZ900 stator & oil inside?
  • ran429
  • Topic Author
  • Master of FREE rides!
14 Aug 2006 11:27 #69350 by ran429
KZ900 stator & oil inside? was created by ran429
ok, I just dont understand why the Stator on a 76 kz900 would be oil filled like a clutch basket.
I stopped a leak of oil on the stator, when i removed the cover it was full of oil.
my understanding is that an electrical part like that for charging should be dry?
i dont get how a stator can make a charge being oil saturated.
You would think it would ground out any current going to the battery for a charge?
14 Aug 2006 11:31 #69351 by loudhvx
Replied by loudhvx on topic KZ900 stator & oil inside?
Oil doesn't conduct electricity, but it's still messy. Apparently some KZ's have the stator in oil. The 550's and 650's (assume 750's-4cyl) are dry. Others have reported that some 900's or 1000's have oil in there. Maybe it was for cooling?
Post edited by: loudhvx, at: 2006/08/14 19:22
  • ran429
  • Topic Author
14 Aug 2006 11:46 #69352 by ran429
Replied by ran429 on topic KZ900 stator & oil inside?
ok, maybe i need to just go purchase a new battery and front tire sooner then, so I can see if i fixed the charging gremlin.
i replaced the regulator and one other black cagey looking electrical part under the left cover, it used to die if i turned on the lights, but now its staying alive.
the bike needs a good day out on the highway with a can of seafoam to ease my mind.
guess i go for tires and a battery today.
Tabs asap also.:dry:
14 Aug 2006 12:49 #69362 by ronjones
Replied by ronjones on topic KZ900 stator & oil inside?
Mine is in oil also
14 Aug 2006 15:21 #69405 by steell
Replied by steell on topic KZ900 stator & oil inside?
ronjones wrote:
Mine is in oil also
The 750 twins need oil there to lube the starter chain and clutch.
Post edited by: steell, at: 2006/08/14 18:22
14 Aug 2006 16:29 #69413 by ronjones
steell wrote:
ronjones wrote:
Mine is in oil also
The 750 twins need oil there to lube the starter chain and clutch.<br><br>Post edited by: steell, at: 2006/08/14 18:22
Hi steell, Does this mean that the reason ran has his stator in oil, is different than the reason my stator is in oil?
14 Aug 2006 17:03 #69421 by RomSpaceKnight
Replied by RomSpaceKnight on topic KZ900 stator &amp; oil inside?
I think there is a small passage behind starter clutch on the 900/1000 that allows oil to splash feed the starter gear.
14 Aug 2006 17:05 #69423 by steell
Replied by steell on topic KZ900 stator &amp; oil inside?
ronjones wrote:
steell wrote:
ronjones wrote:
Mine is in oil also
I don't have a clue, notice that I make no attempt to answer 900/1000 questions, that's because I only have 750 fours and twins :D
  • wireman
  • Visitor
14 Aug 2006 21:14 #69527 by wireman
Replied by wireman on topic KZ900 stator &amp; oil inside?
yeah but theyre cool 750s!;) :P
