tach and speedo lights
  • freebyrd24
  • freebyrd24's Avatar Topic Author
08 Aug 2006 09:30
#68012
can anyone tell me why my tach and speedo light arent working at all? any idea?
Post edited by: freebyrd24, at: 2006/08/08 12:30
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
  • OKC_Kent
  • OKC_Kent's Avatar
Re: tach and speedo lights
08 Aug 2006 09:57
#68016
Burned out, broken wire, bad connection, take your pick. Remove the cover on the gages and pop out the rubber holders that hold the lights and take a look.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • RonKZ650
  • RonKZ650's Avatar
08 Aug 2006 10:01
#68019
Assuming you've already checked the bulbs, the common ailment is a broken wire in your harness. Certain places in the harness they use wire splices. In other words one wire is basically crimped to 2 to "T" off wiring 2 ways from 1. These splices are a major problem with wires breaking. You can either open your wire harness and find the break or simply parellel another wire from a working bulb to one of the nonworking.
