Tach
- minutiesabotage
Tach
07 Aug 2006 20:58
My tach needle came off its mount. It is still inside the gauge, but it is just rattling around inside, not attached to the center needle. I can not figure out an easy way to reattach it. I don't want to force it open in case I break it. Any ideas??
- minutiesabotage
- ltdrider
Re: Tach
08 Aug 2006 12:01
The only way to get access to the needle, is to open the tach.
But it's a bitch.
The tach and speedo meters are held together with a crimped chrome ring that goes around the circumference of the meter. If you uncrimp it, then you can lift off the top half that holds the glass.
Then you can get to your needle, and maybe re-attach it. It's hard to uncrimp the ring without damaging it. If you break it, then you'll have to find some other way to hold the two halves together. If you don't break it, you can use duckbill pliers to re-crimp it when you put your meter back together.
OR...
You can remove the tach and send it to ZResto. They specialize in meter repair/restoration for these bikes.
Here's the link:
www.z1enterprises.com/reference/zresto_home.aspx
Good luck.
But it's a bitch.
OR...
Here's the link:
Good luck.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- mariozappa
Re: Tach
08 Aug 2006 13:10
There is an article in the...articles section that tells you how to get your gauges apart, this should work for getting to your problem.
kzrider.com/content/view/39/11/
1977 KZ650C1
and the KZ650/KZ750 Conversion
