here is a signal question stumper for ya
- Torch
I wouldn't have to worry about it, but my state obviously changed the law one year when i wasn't paying attention and now all bikes made after 1972 have to have turn signals.
- loudhvx
- Thank you received: 1616
Im thinking about using twin Sparto tail lamps, and for a cleaner look, it would be sweet if it were possible to have the corresponding side flash for turn. So how exactly would i need to wire that up to work the way im wanting it to work. I know it can be done, several cars have a single bulb performing all the functions in the tail lamps.
Ahh, good question. How did cars use a single bulb for brakes and turn signal? The switching circuitry was done in the complicated turn signal switch assembly.
Bikes don't have that circuitry in the turn signal switch, so you need an external integrator. You can get them cheap at Farm $ Fleet type stores.
I designed several, but the parts end up costing more than the Farm & Fleet units. Back when I designed them, i could only find $100 integrators for motorcycles. I think the cheaper ones are less than $20 now.
In case your interested: www.geocities.com/loudgpz/GPZturnSigInteg.html
Post edited by: loudhvx, at: 2006/08/07 02:22
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Torch
- btchalice
- Thank you received: 7
i know the image isnt very clear but its all i have right now
Post edited by: btchalice, at: 2006/08/07 08:00
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- Wizzard
Wizzard
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
- Torch
I got a tail light off a newer sport bike (honda) witch has tail and signal intrageted in to it looks clean and like it belongs. I think so anyways.
Wizzard
So the signal converter is made into the tail light? What year and model honda did that come off of? Doesn't look too shabby, and if its an all in one deal...less wiring is always better.
- Wizzard
Wizzard
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- Wizzard
Wizzard
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
- kzwolfsr
Original man of the Caribbean
