76 kz900 turn signals
- wiley90
Thanks
Dean
- trippivot
- Thank you received: 3
power will be at the positive side of the signal light
the flasher units are seperate between 4 ways and turn indicators. switch 'em and test
corrosion at the flasher unit possible excessive resistance
- wiley90
- amedeo
- amedeo
- wiley90
- wiley90
Dean
- wiley90
- loudhvx
- Thank you received: 1616
the switch controls the ground
The signals are grounded. A pulsed 12volt source goes to the turn signal switch which directs the 12 volts to the appropriate signals. The pulsed 12 volts comes from the turn signal flasher relay.
The hazards are pulsed from a different flasher relay.
There are also diodes to prevent feedback loops in the tail light system.
There is also a diode involved with the turn signal beeper.
Inspect or replace the turn signal flasher first (I guess you already did that). If that doesn't fix it, check the diodes. I believe there are at least three diodes hidden somewhere.
Also, you apparently have some crossed wires if the brake switch affects the signals.
The Clymer diagram has a few mistakes in it, so you'll need some general knowledge to identify the errors.
Here's the errors I spotted in just a few seconds:
The front left signal wire is green and should connect to a green wire, not the oil pressure light as the diagram shows.
The left signal ground (black/yellow) should be tied to the other grounds. The diagram only shows it going to the headlight ground.
The diode on the turn signal relay looks like it may be drawn backwards, or in the wrong place.
There are probably others.
Post edited by: loudhvx, at: 2006/08/07 02:50
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- wiley90
Dean
- wiley90
- loudhvx
kzrider.com/component/option,com_docman/...w/gid,264/Itemid,49/
If you look right at the turn signal flasher relay, you'll see a black arrow with a line across the tip of the arrow. That is a diode. The actual diode probably looks like a little piece of plastic in the wiring right at the connector to the flasher.
As I suspected, the Clymer's version is backwards. This factory diagram shows it the right way.
However, I'm not convinced the diodes are your problem. You seem to have some wires crossed judging by the wierd brake switch behavior.
Post edited by: loudhvx, at: 2006/08/07 14:43
1981 KZ550 D1 gpz.
Other links.
