r/r replacement questions
02 Aug 2006 19:49 #66821 by scirocco17
r/r replacement questions was created by scirocco17
Well my battery isnt charging, i think it's my r/r but i didnt troubleshoot it yet. can I use almost any r/r to replace it with? i am thinking about getting one off of ebay. it's for my 84 ltd 700 shaft. what should my next step be? (you are probably gonna say get a voltmeter and troubleshoot that charging syetem) which is planned on... i even have the flow chart printed out!
  • RetroRiceRocketRider
  • ...bring in the machine that goes PING!
02 Aug 2006 20:59 #66845 by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic r/r replacement questions
OR you could just get one that actually came from the same model... 84 ZN700 regulator :whistle:
FWIW, that regulator (part# 21066-1055) fits a plethora of Kaws!
86~93 KLF300 (Bayou)
86/87 ZL600 (Eliminator)
85~93 ZX600 (Ninja)
85 VN700 (Vulcan)
86~93 VN750 (Vulcan)
91/92 ZR750
84/85 ZN1100 (LTD)
87~93 VN1500 (Vulcan)
It may also fit some newer models, but the cross-reference software I have only covers up to '93.
BTW, if you run across an extra set of gauges (or at least the inner speedo unit) for a ZN700 lemme know.
My speedometer gave up the ghost (no longer available through Kawi either :( ) a couple of weeks ago and I need another one
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
03 Aug 2006 06:09 #66886 by trippivot
Replied by trippivot on topic r/r replacement questions
try mrcycleparts.com for used parts
03 Aug 2006 10:38 #66931 by scirocco17
Replied by scirocco17 on topic not r/r... stator
well i did the troubleshooting chart and since i am getting like 8 volts on my yellow wires it must be the stator, not the r/r that is the problem. (the problem is that my battery is not charging at all and the bike runs ONLY on battery power; disconnect the battery, the bike dies.) now, on to these questions: where to get one at a low cost? is it zn700 specific or can someone cross referance it for me? is it hard to replace?
i just rebuilt a new 318 for my dodge from the oil pan to the intake so i have a little mechanical ability but not much experience with motorcycles.
thanks
03 Aug 2006 10:49 #66935 by steell
Replied by steell on topic not r/r... stator
As long as the number of wires and the connectors match, then 650-750 stators should work.
If you can't find one, send me a PM as I think I might have a spare GPz750 stator here somewhere.
Post edited by: steell, at: 2006/08/03 13:49
03 Aug 2006 11:38 #66940 by loudhvx
Replied by loudhvx on topic not r/r... stator
Disconnecting the battery, even on a working charging system, while the bike is running will often kill the bike. That is not necessarily a sign of a bad charging system. It's also a very bad idea to do that. If the charging system was working, the regulator can't regulate properly without a battery (or battery eliminator device) and you may fry some electricals.
If that 8 volts was 8v AC, wire-to-wire (3 yellow wires, not to ground), with the wires disconnected from the rec/reg, then yes, sounds like the stator, or the yellow wires going to the stator.
03 Aug 2006 17:54 #66998 by cnyl
Replied by cnyl on topic not r/r... stator
I didn't know what an r/r was...:blush: :whistle:
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
