Low Power
  • Frazzles
  • Frazzles's Avatar Topic Author
Low Power
26 Jul 2006 17:44
#64991
For some reason I'm not getting much power to my bike. I have a brand new battery and new fuses. The front light is very dim and the turn signals and horn do not work. Could this be the wiring or what else could be causing this?
Thanks
  • hydrolazer
  • hydrolazer's Avatar
Re: Low Power
26 Jul 2006 18:13
#64997
do you have the correct battery installed and is it fully charged?
\'79 kaw 1000 ltd
  • Frazzles
Re: Low Power
26 Jul 2006 18:31
#65001
Yes I do have the right battery and it is fully charged. I went to Autozone and got the battery about 3 days ago and I just had it fully charged there today.
  • steell
  • steell's Avatar
Re: Low Power
26 Jul 2006 23:04
#65074
Use a multimeter and check the resistance between the negative post of the battery and the frame, then between the negative post of the battery and the engine, you may have a bad ground connection.
