Turn Signal on drugs
- kawaduce
17 Jul 2006 09:22
This is probably a stupid question... BUT:
When I ride slowly the turnsignal behaves nice and seems to be in harmony... But when I ride not so slowly (or past my neighbours house in 1st gear, 9000 rpm) the turnsignal looses its harmony and blinks insanely fast. Is this the way it should be, or am I missing some regulator or such?
KZ1100B2 1982 - carb converted
- ambergrismooon
Re: Turn Signal on drugs
17 Jul 2006 09:33
I bet the neighbor has the Ronko Motorcycle Hyper Blinker Microwave Bazooka and Rotisserie. Just set it and ferget it! Maybe a ballast resistor getting weak? You'll get some better answere just stay tuned!:whistle:
- kawaduce
17 Jul 2006 10:10
Actually... you might be right about rotisserie and my neighbour...
- wiredgeorge
17 Jul 2006 12:44
If I owned your bike, I suspect I would get a multimeter and check the bike's battery voltage at idle and then at 4K rpm. It should be about 12.5 VDC at idle and about 14VDC at 4k rpm. If the voltage is in excess of much more than 14VDC at 4K rpm, I would start thinking about investing in a new regulator/rectifier as it is probably going. If the voltage is OK at 4K rpm, I would replace the turn signal flasher relay. You can get them at any autoparts store for under $5. They are barrel shaped and have two prongs arrayed as an |_
type deal.
type deal.
- wireman
17 Jul 2006 15:35
thank god!i thought gris passed out on his bike and left the turn signal on again!:S
