speedometer
  • hydrolazer
  • hydrolazer's Avatar Topic Author
speedometer
03 Nov 2026 16:56
#928909
on my 1975 h2, my speedometer really acts crazy.the needle jumps all over the place .when it gets steady i can in 5th gear and the tach shows 3000 rpm ant the speedometer will show im doing 70 mph and i know im not going that fast. has anyone ever had that problem?   tia...hydro
\'79 kaw 1000 ltd
  • asphalt900
  • asphalt900's Avatar
Re: speedometer
04 Nov 2026 04:36
#928915
A few common issues with these. I would pull the whole assembly off to check this stuff, they of course come off as an assembly. Check with a drill in reverse using a square drive per each gauge. These are prone to gauge cable input thread detaching, see it all the time. You will note this upon removal of female barrel of cables. Next thing is the weeping of damper fluid from cup down into rotating drive bell and needle mechanism stop. The fluid, contrary to a lot of AI Slop, isn't oil at all. Its a silicone based "tacky, not slippery" fluid. This, while great for dragging the needle around, isn't great when it spills onto the mechanical magnet and drag cup assy. Being a 1975 H2, you should have speedo faceplate with 10th increments and tach with a 7500rpm redline, not like one shown but internals are identical. Try the thread checking and drill technique first, everything else the gauge has to come apart.
  • hydrolazer
Re: speedometer
07 Nov 2026 15:06
#928974
also  the speedo is reading way faster than im going    fifth gear and tach at 3000 rpm i know im not doing 70 mph... the front tire is the correct size also....can a bad cable be the problem?
\'79 kaw 1000 ltd
  • asphalt900
Re: speedometer
08 Nov 2026 03:19
#928978
A cable isn't going to make a gauge show faster. Your woes are gauge related
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: speedometer
08 Nov 2026 03:20
#928979
A mechanical speedo is generally governed by “gear ratio’s” is it the correct clock and does it have the correct drive on the wheel
  • the don
  • the don's Avatar
Re: speedometer
08 Nov 2026 09:28
#928983
cannot believe how much information is passed around onthis forum
thank you every one for your input
  • hydrolazer
Re: speedometer
08 Nov 2026 13:12
#928987
yes a lotof very usefull information in here with very knowledgeable people...question 1...where would you get the correct speedo gear for a 75 h2 and question 2..what is the proper way to install the speed cable after you have lubed it?...tia again,,,hydro
\'79 kaw 1000 ltd
  • asphalt900
Re: speedometer
09 Nov 2026 02:27
#928997
Questions you are asking are irrelevant to your issue. The wheel hub case with pinion/gear are identical to the Z1 900. They did have a couple versions but merely cosmetic. Believe gear is 29T and pinion is rarely removed. Cable installation is self explanatory, just screws on with the thumb barrels. So unless radically changed to a different front wheel hub, which you did say you had the correct 19" front, NONE of this will cause a speedo to show waaay too fast. Again..it's an internal or broken drive clock issue, not external. Post a couple photos of speedo drive and wheel also the gauge.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: speedometer
09 Nov 2026 02:49
#928999
Always happy to bow to your greater knowledge on these things Clay, simply suggesting that an incorrect drive ratio on the front wheel could cause this issue if parts had been swopped (always a possibility on vehicles over 50 years old)
  • asphalt900
Re: speedometer
09 Nov 2026 03:04
#929001
Here's the issue. Spinning magnet to this drum shown. This is identical to yours. Magnet spins internally within this drum but NEVER actually physically touches it and drags the needle around. Any funk/debris built up between that air-gap will cause the needle to spike or erratic behavior will be assured. A broken magnet (drive unit) will do the same causing the unwanted physical contact between these parts. Also, rare on these, that central bushing can get worn out causing the drum to wander around.
  • KeylAmi!
  • KeylAmi!'s Avatar
  • Engineer with ADHD
Re: speedometer
10 Nov 2026 11:35
#929031
I was going to mention that there is a process you can do to "recharge" the mag drive types... but in this can I think that would be worse! A recharge would only work if the speedo/tach was slower than actual. Not faster.
Current project:
'84 KZ700
  • asphalt900
Re: speedometer
13 Nov 2026 04:20
#929081
Please elaborate Key! What's your procedure for adding to the magnet? And how to control it?
