Coil Pickups KZ750
- Outacontrol
Coil Pickups KZ750
08 Oct 2026 00:38
Hey guys, KZ 750E1 possibly E2
What's the fifth wire on coil Pickups ?
Runs to the crimped on bullet plug.
Re: Coil Pickups KZ750
08 Oct 2026 00:46
I believe the wire coming from behind the plate is for the oil pressure switch
- Outacontrol
08 Oct 2026 05:45
Ahhhh, that would probably explain the bullet end... Thanks heaps for the reply, appreciate it 👍👍👍
- H1Vindicator
08 Oct 2026 06:22 - 08 Oct 2026 06:26
in your photos. there is a wire going thru the pulsing coil plate. probably to the oil pressure switch.
750E oil pressure switch should be the same as the 650-csr. uses a fork terminal. wire should be blue/red on both. 1981 KZ650-CSR >>
Last edit: 08 Oct 2026 06:26 by H1Vindicator.
The following user(s) said Thank You: Outacontrol
