wiring loom cover material
  • kawikid
  • kawikid's Avatar Topic Author
29 Aug 2026 13:08
#927095
hey y'all, my 76 KZ900 wiring loom has a mix of covers, i am guessing those that are continuous plastic tubes of differing sizes are the original, others are spiral wrapped electrical tape, see attached pictures, does anyone know where i can get the original continuous plastic tubes i would like to return it all to original ? many thanks
Kawikid
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: wiring loom cover material
29 Aug 2026 14:02
#927097
Check out VintageConnectors or CycleTerminal.  One or both has the plastic sheathing..I just can’t which one for sure.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • TexasKZ
  • TexasKZ's Avatar
29 Aug 2026 15:16 - 29 Aug 2026 15:17
#927099
Last edit: 29 Aug 2026 15:17 by TexasKZ.
The following user(s) said Thank You: StreetfighterKz
  • Nessism
  • Nessism's Avatar
29 Aug 2026 18:09
#927104
Regarding the tape, it's commonly glueless, with just a little regular adhesive type electrical tape on the ends to hold it together.
  • asphalt900
  • asphalt900's Avatar
30 Aug 2026 02:32
#927116
The tape that all those harnesses use has adhesive but it's very slight, just enough to keep it in place. I buy mine from Vintage connections along with all the matching equivalent white "non-latching" male/female connecting blocks and terminals/spades. They Don't unfortunately have any of that PVC sheathing big enough that covers wiring from under tank to headlight bucket though. I bought a huge roll of that years ago from an electronic surplus store in Kansas City, local to me.
  • Warren3200gt
  • Warren3200gt's Avatar
30 Aug 2026 03:36 - 30 Aug 2026 03:37
#927119
Use almalgum tape. Sticks to itself but not the loom. 100 %  waterproof overlaps and  joints.
Last edit: 30 Aug 2026 03:37 by Warren3200gt.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
30 Aug 2026 03:41 - 30 Aug 2026 03:46
#927120
   We've used black heat shrink tubing for solid harness sheathing where the sheen isn't important.  It's not glossy like vinyl sheath, and has never shrunk during hours of summertime  direct sun exposure.
   The spiral harness wrap tape is called 'dry vinyl' tape.  Sticks only to itself with no messy adhesive residue like typical electrical tape.  Same type stuff used on long runs of bundled wires such as under tank and along frame rails.  We bought some from amazon, but it's available from many vendors.  Example:
tapecase.com/products/tc790-black-non-adhesive-dry-vinyl-tape
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 30 Aug 2026 03:46 by slmjim+Z1BEBE.
  • kawikid
01 Sep 2026 09:23
#927180
Thanks to everyone for the excellent feedback on what and where to buy, now its off i go on wiring loom madness
Kawikid
