GPz750 won't rev over 8,000 rpm?
- Buffalo BiL
30 Jul 2026 07:45
Hi Folks, I have my 1985 GPz750 working very good, however it seems like the rev limiter kicks in at 7,500 RPM.
I've tried a few sizes larger main jets with no difference, 115, 120 & 125.
Plenty of power up to 7,500 RPM, then it drops off. When I back off the RPM to below 7,000 the power comes back on.
Is this a problem with the Igniter? Part number 21119-1069
Bikes owned:
82 Suzuki GS1100G
87 Honda CBR600F Hurricane
90 Suzuki Katana 7/1100 conversion
85 Kawasaki GPz750
82 Suzuki GS1100G
85 Kawasaki GPz750
- asphalt900
Re: GPz750 won't rev over 8,000 rpm?
30 Jul 2026 09:44 - 30 Jul 2026 09:46
Do you have the Original Airbox? Without it, isn't going to happen. There is No rev limiter on these older machines, just lack of restriction.
Last edit: 30 Jul 2026 09:46 by asphalt900.
- Buffalo BiL
30 Jul 2026 11:01
Thanks and yes I have the airbox in place.
Bikes owned:
82 Suzuki GS1100G
85 Kawasaki GPz750
82 Suzuki GS1100G
85 Kawasaki GPz750
- chopper1963
30 Jul 2026 11:51
I would start swapping all electronics, one at a time.
The following user(s) said Thank You: Buffalo BiL
- Buffalo BiL
30 Jul 2026 12:26
Thanks, I agree.
Bikes owned:
82 Suzuki GS1100G
85 Kawasaki GPz750
82 Suzuki GS1100G
85 Kawasaki GPz750
30 Jul 2026 12:30
Have you checked the ignition advancer to be sure it is working? Rust or old, dried up WD40 can gum them up.
Could also be bad diaphragms in the, carburetors, preventing the needles from lifting fully.
Personally, I prefer to test and confirm that components are bad before replacing them.
There is a factory service manual in the file base. It describes quite a few testing procedures.
The following user(s) said Thank You: StreetfighterKz, Wookie58, Buffalo BiL
- StreetfighterKz
30 Jul 2026 13:14
I agree with TexasKz. Get a FACTORY service manual and start troubleshooting. I have a ‘83 version and it does not have an advance mechanism on the crank, just a rotor.
Go through everything methodically otherwise you may be throwing unneeded money at it.
What do the spark plugs look like? Are the jets you’re using genuine Mikuni? Aftermarket fuel filter? Clean screen at the fuel tap? Float height set correctly? Yada yada yada….
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Wookie58, Buffalo BiL
- Buffalo BiL
30 Jul 2026 14:41
I'm way past beginner suggestions my friends, thank you anyway.
Bikes owned:
82 Suzuki GS1100G
85 Kawasaki GPz750
82 Suzuki GS1100G
85 Kawasaki GPz750
- StreetfighterKz
30 Jul 2026 15:43I have ZERO idea what you have or haven’t done other than you still have a stock airbox and you’ve tried different main just sizes per this thread. Hence the questions.I'm way past beginner suggestions.
You can either help us help you or start throwing stupid money at parts it may not need.
Sorry if i come off as rude, but don’t ask for help and then ignore it.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: asphalt900, Buffalo BiL
- F64
- 81-KZ440D2
30 Jul 2026 15:44 - 30 Jul 2026 16:16
Plug chop it.
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 30 Jul 2026 16:16 by F64.
- asphalt900
31 Jul 2026 00:45
No canned answers ya say ha. Have to ask, did it ever run correctly during your possession of it? Probably won't apply but years ago i did a set of the stock BS34's for a Friend. It too was all stock KZP1000, wouldn't rev to redline. He too kept going up in main jetting to no avail. Come to find the stock exhaust 4 into 2 had rotted baffles and were blocking off exhaust output. Pipes from the outside looked almost new too! See, that's not a pedestrian answer.
The following user(s) said Thank You: !Seymore, Wookie58, Buffalo BiL
- Buffalo BiL
31 Jul 2026 04:46 - 31 Jul 2026 04:46
Thanks for all contributions my friends. Just for background, I have been re-fixing motorcycles for 20 years and before that cars since the late 70s. I buy repair manuals too.
This GPz I'm tuning is new to me, and had been in storage since 2008. It needed a lot of work. The PO installed pod filters and 4>1 headers.
I installed an OEM airbox complete with a Uni foam filter, and new slip on muffler.
I only have 350 miles on the bike since restart.
Right now I'm testing with 115 main jets and it seems to be reaching 8,000 RPM. Maybe it's over jetted and flooding out?
After testing it for 100 miles, I'll try 110 main jets.
Next option will be replacing ignition coils.
Thanks
Thanks
Bikes owned:
82 Suzuki GS1100G
85 Kawasaki GPz750
82 Suzuki GS1100G
85 Kawasaki GPz750
Last edit: 31 Jul 2026 04:46 by Buffalo BiL.
