Ignition coils
- askrider19
Ignition coils
12 Jul 2026 15:08
Hello All I hope you are all doing good.
. I was just wondering if you can recommend a quality set of coils. For a kz 750 e1 1980 . As I have a fault on on of them.
thanks for all your help.
Andrew
Andrew
The following user(s) said Thank You: bound
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
Re: Ignition coils
12 Jul 2026 19:50
I hear that dyna coils are widely used here. Make sure you purchase the correct ohm rating.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
The following user(s) said Thank You: askrider19
- askrider19
Re: Ignition coils
13 Jul 2026 18:30
The stock coils are 2.3 ohms.
- H1Vindicator
Re: Ignition coils
14 Jul 2026 06:38
closest to stock are the grey 2.2 ohm dyna coils. the green 3.0 ohm dyna coils are also suitable. and secified w the dyna S. I'm running the stock ignition w the green coils. worth noting is you'll need to fab up some simple mounting brackets w the dyna coils.
- askrider19
