1982 Kawasaki GPZ1100 fuel injected throttle response problems
  • battman78
  • battman78's Avatar Topic Author
16 Jun 2026 10:10
#924952
When I start the bike, the idle is not spot on and fumbles badly from 3000 on. If I blip the throttle it will sometimes just die.
Here is what I have done so far: New plugs, injector cleaner put in gas, pulled the connecter from the DFI/TPS and cleaned with right product. Measure the ohms resistance on the plug and between the left to far right is 6.9 ohms, between the left to next over no reading. I was told that with this bike that the middle connector is on a separate sensor and I could test it by using the buzz option of my meter but still no response or sound. When I test the ohm reading and open the throttle again there is no change. Can't tell if it is starving for gas or getting too much. Checked temperature of the pipes after running and they were all pretty even, so I have concluded that the cylinders are all definitely firing. It seems that I need to get deeper into checking sensors but not sure which ones? Will put up a picture on next post. Thank you for the privilege of being able to ask people who have already experienced the problems. John
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: 1982 Kawasaki GPZ1100 fuel injected throttle response problems
16 Jun 2026 13:02
#924961
John
Welcome to KZRider
Please make your next post a introduction in our New Members forum
Once done I will release any further posts you make here
Thanks
Site Moderator
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
17 Jun 2026 01:27 - 17 Jun 2026 01:30
#924979
Hi and welcome from the UK. Here is a couple of previous threads that might help although don't forget you still have intake rubbers that harden and leak and also rubber injector seals which will also harden and leak
PS: fuel additive won't clear clogged up injectors no matter what it says on the tin !!!!
dfi - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
1980 z1 classic fouling plugs - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
Last edit: 17 Jun 2026 01:30 by Wookie58.
