Time to replace the coil packs?
  • Shdwdrgn
  • Shdwdrgn's Avatar Topic Author
17 May 2026 21:59
#924016
I'll start off with the basics... 1981 KZ1000, rebuilt with parts from a couple different bikes, everything is pretty much original.  The coils were probably weak when I first put it all together, I've always had that gas smell from it running, and it never had a whole lot of power (which is why I'm leaning towards coils here).
Trying to get it going this week for the season, but it's just not happy.  Cranking it so much that it's pumping gas onto the ground so I presume flooding out the cylinders.  It does eventually start but there's very little throttle response.  Cleaned the plugs twice.  Today when I cleaned them, inside right cylinder plug is completely covered in carbon.  If I can get it going long enough to ride up and down the street, it takes a lot to keep it running, and there's backfiring on the right side.  The left side seems better, but still not putting out a lot of heat to suggest that it's really running well.
Another thing today, after cleaning the plugs and getting it to start again...  I can barely keep it running, but then something catches and it jumps up to 3000rpm.  It'll run there for a couple minutes, then choke itself out and die again.
So from my knowledge, this all points to little or no spark.  If anyone has other ideas, let me know?  (Erg it just occurred to me that I should have pulled the cap to check the points.)
And if the coils are indeed the problem, then the question becomes what should I replace it with?  I'm hoping to keep it simple, something that is a straight OEM replacement that can drop right in without having to do any rewiring.  Modern replacements are fine but this is just a street bike so I don't need anything fancy.  If there's something I can snag off Amazon then maybe I can try doing the swap next weekend.
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
  • Nessism
  • Nessism's Avatar
Re: Time to replace the coil packs?
18 May 2026 05:34
#924026
Coils get a lot of blame, but rarely fail.  You can measure their resistance.  If you really want to do a solid, replace the leads with 7mm copper core spark plug lead wire, and measure the cap resistance, or just replace the caps with new 5k ohm caps.
Regarding the running issues, it's hard to say.  Likely carbs.
The following user(s) said Thank You: asphalt900, MFP-Joe, Warren3200gt
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 May 2026 07:15
#924029
When checking coil resistance don't forget to check between primary and secondary windings (should be infinite) and also between both windings and the mounting post (should also be infinite)
  • Warren3200gt
  • Warren3200gt's Avatar
18 May 2026 07:47 - 18 May 2026 07:50
#924032
Stinks of fuel, black carboned plugs, it obviously running way too rich.
you only need choke to get it warm, if you leave it running on choke until it dies then your plugs will have carboned up to the extent they'll no longer spark. If they are ngk plugs and get to that stage they are almost impossible to get back in decent shape regardless of how much cleaning you do.
ALL your description points to overly rich mixture and carb tunning and nothing to do with weak coils.
if you truly believe you have weak coils, or low voltage to the coils, test them as per fsm and fit wired george mod to facilitate full battery voltage to the coils.
Last edit: 18 May 2026 07:50 by Warren3200gt.
  • ckahleer
  • ckahleer's Avatar
18 May 2026 08:10
#924035
Swap the leads to the #2 and #3 plug. Or switch the coils around. See if it is the same spark plug that gets carbon fouled.
Run the bike in a dark place. look for electrical arcing from the coils and plug wires.
You can also make a simple spark distance tester with a block of wood and solid copper wires.
In my experience, I have never found a weak coil. They are either good or bad.
Carbs are more likely the problem.
1997 ZL600
94 KE100
82 KZ305
74 TC185
The following user(s) said Thank You: asphalt900, sf4t7, Wookie58
  • Shdwdrgn
18 May 2026 09:17
#924037
Wow ok, so it sounds like I'll be pulling the carbs.  Maybe a stuck float or something?  When I rebuilt the bike I also rebuilt the carbs, so new floats, gaskets, valves, and of course spending the time to adjust the float heights... it would suck if anything actually went bad already.
So just to clarify... I originally pulled the bike out Friday afternoon.  I was able to get it started with a lot of effort (which was surprising because last year I didn't even have to charge the battery, it just fired right up).  I had to jump-start it because the battery was nearly dead so that's when I was trying to ride it up and down the street, but that's also when I was cranking it so much that fuel came out onto the ground.  Then Saturday I thought to clean the plugs -- they weren't terrible, but they were all wet.  So when I got back to it again yesterday I still had to use the jumper cables.  There was no flooding onto the street this time, but even when I got it to start it would barely run.  So I pulled the spark plugs again, that's when #3 was carboned up.
Regarding the choke... I have never been able to start it without being choked.  Most of the time even when it's hot it still won't start without some choke.  Yesterday I tried starting in all three positions to control the flooding, but it still would only try to start when fully choked but with the throttle cracked a little -- which is different than previous years where it needed to be fully choked and the throttle fully closed.
So other than checking float height and the valves, anything else I should pay special attention to when I have the carbs apart?  I am assuming there is going to be issues across all four, otherwise the bike should be able to run on only three cylinders (albeit rough).
1981 KZ1000-JK1
  • ckahleer
  • ckahleer's Avatar
18 May 2026 12:26
#924043
Before disassembling the carbs, do a clear tube fuel level check on them.The problem may be only that one carb is flooding.
When finished working on carbs, I always do a bench test clear tube fuel level check, using a fuel bottle. It catches problems before mounting carbs back on the bike.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • Shdwdrgn
18 May 2026 19:15
#924054
Sheesh it's been so many years ago that I completely forgot about that method.  I'm pretty sure I used some extra aquarium tubing to calibrate them to begin with, and we still have plenty of that kicking around.
1981 KZ1000-JK1
  • TexasKZ
  • TexasKZ's Avatar
18 May 2026 21:04
#924056
Is the engine oil level really high or does it smell like gasoline? Could be float valves not sealing. The clear tube method will show really high fuel levels if the float valves not sealing is leaking.
Also, there are no points to check. The 1981 1000s have electronic ignition.
The following user(s) said Thank You: BCScott
  • Shdwdrgn
16 Sep 2026 21:47 - 16 Sep 2026 21:57
#927648
Well... it's been a Summer.  Mom fell down and broke her neck so most of my weekends have been spent helping her out.  I'm finally getting some time to work on the bike again.
Here's what I've found.  First off, the air filter hasn't been touched in a decade (whoops!) and is packed full of oil and dirt.  That alone could have been the whole issue.  OK, I decided to order one of those foam styles since they're worked well on my truck and I have the oil for them.  Seller shipped the wrong part so I'm waiting for the next shipment.
Meanwhile I got the carbs off the bike and finally cracked them open yesterday.  And oh boy.  The bottom of the bowls (the depression where the drain screw sits) was completely full of rust.  I feel like that could have accounted for the wild bowl level measurements I took in the Spring?  OK fine, obviously I need a better quality fuel filter.  Cleaned out the bowls and was shooting water through the jets, and wouldn't you know it, I dropped the last one in the yard and couldn't find it.  OK I'll grab a new set.  Except everything I find says they should be 127.5 and these are 122.5.  The bike was rebuilt with parts from a J and a K, and something bad got stripped out when trying to reassemble the J carbs so I ended up rebuilding with the K's.
Now this has me wondering if the size difference accounts for the weak throttle?  I still have all the J carbs and their parts, so I want to take the main and needle jets, and the jet needles from J carbs and fit them into the K carbs.  Hope that made sense?  Those parts seem easy enough to swap, but my big question is whether anything ELSE also needs swapped?  Like I'm thinking the plastic spacer disc that the needles sit on were different thicknesses but I believe the slides are the same for both?  Anything else I should worry about, or does this pretty much cover the important differences?  And I saw something about differences between the airbox between these two bikes -- how would I tell which one I reinstalled?
If it's that simple then I'll get everything rebuilt this weekend and start working on trying to squeeze the carbs back onto the bike.  I still need to find a finer fuel filter that won't let all this rust through (I saw recommendations on 10-40 micron), but then I can fire up the engine while waiting for the new air cleaner to see if there's any improvement.  Hmm I should also remember to throw the battery on the charger tomorrow.
[Edit] Oops... I forgot the pilot jets!  I have one set of the four parts pulled from one of the J carbs, and they all match the model numbers or sizes I expected.
1981 KZ1000-JK1
Last edit: 16 Sep 2026 21:57 by Shdwdrgn.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
16 Sep 2026 23:26
#927649
J is jetted differently as it has hotter cams than a “K”
  • Shdwdrgn
17 Sep 2026 06:52
#927659
Yes, quite a bit differently it seems.  But this is a J engine and at its core it is a J bike.  When I rebuilt it, I had a lot of parts from a KZ1000-K on hand as well so I took the components that were in the best condition from both bikes.  Part of the frame, most of the electrical including the wiring harness came from the K.  I don't remember if the air box came from the J or the K, but the carbs definitely came from the K.
1981 KZ1000-JK1
